Could Use Some Help
Could Use Some Help
Hey Scionlife peeps,
Does anybody want to help me try putting in my new white led rear dome light, trunk light, and cubby? My brother and I changed the trunk light to the white led light and it worked fine, but when we tried to change the rear dome light to the new white led the front dome lights didn't turn on anymore along with the trunk light. I seriously don't know what happened and was very frustated and upset and gave up. Any help would be appreciated. By the way I didn't try changing the cubby light because I couldn't seem to get my big hands to fit through the hole when I tried to remove part of the passenger side of the rug. Now part of the rug is sticking out and I can't seem to get it all in back to place
Originally Posted by dodaddy
truck light or trunk light? Maybe a fuse was blown? Where did you get the new led lights at?
try taking out the trunk LED and putting just the rear dome light and see if it lights on, if not if you open the fuse box theres a diagram that shows you which one is for the Dome lights, i forgot what it says though, but pull it out and see if the fuse is blown. I had to do that when my HID's stopped working, it sucked
i think he meant the bulbs are loose
If you're still having trouble with this shoot me a PM and I will see if I can help you out. I've done a number of full lighting replacements in tC's.
I have Thursday off due to the New Year and will be unpacking but I might be able to find some time to take a look at it.
Originally Posted by KRider830
Not to jump start an old tread, but give Jeremy a call. He is pretty knowledgeable about the lighting systems, he can walk you through anything that need to be done.
