Plz Help Engine Problem
Had Maintenance Done at a Dealer will not name it until Issue is Fixed or Solved but my engine was Dry no Oil at all Well, Now it seems like I will need a rebuild.
Loud Click Noise is made when on so friends that modify Cars told me to Never turn it On again until a mechanic looks at it So I don't make the problem Worse Any Help would be appreciated_
Either what can I do to have the dealer take responsibility or Someone Outside fix my Car_
It's a 2008 Scion xB_
I live in LA_
Thank You
I live in LA_
Thank You
Last edited by MR_LUV; Mar 2, 2018 at 11:14 AM. Reason: Title in All Caps (Shouting)
Got my Car back seems normal so far been driving it very carefully and trying to listen tot he motor as much as i could one issue i did see i have the aftermaket strut header where it connects to s pipe at the bottom it has 2 bolts with springs remember them clearly well i saw now it only has one on one side gonna just buy one tomorrow and put it on myself but the issue i saw its that i guess when they tried to remove it they broke it off in there on the strut header any advice if its hard to remove on how i can get ti off easily
Just had it stall on me again seems like when I wanted to go beyond 18mph it couldn't go wanted ti but got held back but when but got held back again Plz help with this called the dealer now they say only my engine is covered that might be a Transmission problem the guy at maintainence said What did he mean but that idk but they dont have time to look at it until Monday Morning
Another detail that was that i was stuck in traffic for the first time since i got my engine rebuild and had the AC on like normal at 2 on the freeway idk if that can change the reason why my car went into limp mode But the maintenance guy said it might be another issue now and not the engine anymore sounds funny to me since i had no issue with my car ever before
And welcome to dealer repaired engines. Had a friend who had to have his engine repaired at the dealer due to it being under warranty and it never did run right after that. If you can take it to an independent shop before and have them diagnose it so you have a second opinion before the dealer looks at it again.
Took it to different dealer since the other one seemed in a rush then seemed to want to blame it on another issue transmission so I was like i don't trust them anymore they where complaining about a 30 dollars a day rental car and that's why the where in a rush
I was like really but i was like i guess they know what they are doing but was wrong. I took a video my engine as soon as they took it out to hand it to me said the big rattle that I had complained about was because it was new so to put some miles on it
I did for this time I had it it still rattled hard so i showed them the video and where u can clearly hear it I was able to drive it 30 minutes to the dealer on the freeway after it was shut off for a day then before i turned it on had the battery unplugged and seemed
back to normal but didn't want to get stuck again tomorrow I'll be calling headquarters to complain and send them video i have of the engine and that the tech at the other dealer said no way that was normal even for a rebuild engine it would rattle hard to the point
that the hood would make noises Lets see what my luck is they said they where gonna open the oil pan to see if the other dealer messed up something.
And guess what I got card in the mail about my engine having Oil Consumption issues that if i had a problem I could bill them well to late for that letter now
Lets see what this other dealer finds.
Wow. Not to trying to diss you, but your posts are really hard to read and sometimes comprehend.
Did they install a new engine or what is it that they did? Did they give you anything in paper stating what the issue was and how it was resolved?
cid_mcdp
Jan 5, 2015 02:45 PM
fluxingnation
Dec 26, 2014 04:28 PM
