Regional - Southeast FL, GA
Install my gauges
Old Dec 29, 2006 | 06:42 AM
Yankee21's Avatar
Default Install my gauges
Anyone want to install my gauges? (Boost, EGT, Air/Fuel) They will go in the Garage1217 carbon fiber 3 gauge panel which also needs to be installed. I will pay for this... I will drive to your house... Thanks for the help!
Old Dec 29, 2006 | 01:42 PM
SickleCell's Avatar
lol... I'm going out today to get mine installed at a shop
Old Dec 30, 2006 | 12:09 AM
TianaTC's Avatar
pm sent
Old Dec 30, 2006 | 01:23 AM
AmluxTRD's Avatar
Scion Dynasty
Default Re: Install my gauges
Yankee21, chequea el programa de radio, Sabado a las 9am por la estacion 1030AM se llama Revoluciones por minuto, ese es el programa que quiere ir a SKA y entrevistar
Saludos
Old Jan 10, 2007 | 11:49 PM
Crippie's Avatar
1UP Crew
que tiene que ver la programa con el instalacion? lol
Old Jan 11, 2007 | 02:21 AM
Yankee21's Avatar
jajaja eso mismo digo yo?
Old Jan 11, 2007 | 02:28 AM
Neothin's Avatar
Mel... when are they comming to SKA to check it out? I'll make sure i have the tC cleaned up for that meeting.
yankee, as for the gauges... the wideband is going to need a bung welded onto your header. The egt will also need something for the probes mounting in the header.
the boost i dont remember what you have to do off the top of my head
if no one comes forward, titan motorsports on goldenrod did a friend of mines tC when he got his Greddy turbo installed, and his gauges work perfectly
Old Jan 11, 2007 | 03:06 AM
SickleCell's Avatar
boost should just tap into a vacuum line leading into the throttle body....that is if it is set up like a vacuum gauge.
Old Jan 19, 2007 | 08:29 PM
AmluxTRD's Avatar
Scion Dynasty
Yankee21 did you get those installed and ready
Old Jan 20, 2007 | 01:55 AM
Yankee21's Avatar
nope
Old Jan 20, 2007 | 04:40 AM
nolanspawn's Avatar
None of these are very hard to install. The EGR obviously a bung would need to be made for the sensor, thats cheap at an exhuast shop. However the rest of the guages and wiring could be done, get the bung made and you will already have the rest hooked up.
Josh
my06tc
Jun 25, 2015 12:18 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
mattjk
121
Dec 22, 2004 10:49 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
