Brake bleeding and engine coolant changing questions
Need to work on my wife's 16 iA, planning on changing the Coolant, change brake fluid and bleed brakes, and bleed the clutch
EDIT: already bled the brake lines, no problems there 1) where is the engine block coolant drain plug, not the radiator drain plug but the one for the engine block 2) where is the bleeder valve for the clutch? I think it's on the slave cylinder but where is that? An what is the process for bleeding the clutch lines? Thanks! |
