Scion iA Forum - The new stylish Scion sedan
Brake bleeding and engine coolant changing questions
Old Apr 21, 2019 | 01:07 PM
Pariah0x29a's Avatar
Default Brake bleeding and engine coolant changing questions
Need to work on my wife's 16 iA, planning on changing the Coolant, change brake fluid and bleed brakes, and bleed the clutch
EDIT: already bled the brake lines, no problems there
1) where is the engine block coolant drain plug, not the radiator drain plug but the one for the engine block
2) where is the bleeder valve for the clutch? I think it's on the slave cylinder but where is that? An what is the process for bleeding the clutch lines?
Thanks!
08xB714
Jul 12, 2021 01:25 PM
JOHNNYZX10R
Sep 5, 2017 12:12 PM
Luisfc1972
10
Feb 20, 2017 01:10 PM
toolz
10
Mar 24, 2013 05:37 PM
gp1817
Sep 9, 2010 02:54 PM
