Scion iM Forum - Newest compact hatchback
Scion iM Hardwiring Dashcam
Old 01-04-2019, 02:24 AM
scionownerguy's Avatar
Default Scion iM Hardwiring Dashcam
I wanted to hardwire a dashcam into my scion iM. I plan on using a hardwire kit from the dashcam maker and on the site it asks for the fuse type. Which fuse type does the 2016 Scion iM use so I know which one to buy?
Also, where is the fuse box to plug in the dashcam located? A diagram I saw on google showed it under the hood while the other showed it under the steering wheel.
ATS, ATC, Mini, Micro2 are the ones listed on the site.
scionownerguy is offline
Old 01-04-2019, 05:14 AM
4150's Avatar
The iM uses low profile mini fuses(far right fuse pictured above), fuse box is located under the dash on the drivers side right behind the OBDII port. This is the fuse box you want to use if you are installing an add a circuit like you have pictured.
Check this video, makes it a bit easier https://www.carcarekiosk.com/video/2017_Toyota_Corolla_iM_1.8L_4_Cyl./fuse_interior/replace
4150 is offline
Old 01-09-2019, 08:30 PM
got it. seems to be working fine so far. Thanks!
hross
Scion xD ICE & Interior
13
09-23-2023 12:04 PM
mrmemo1464
Scion tC 1G ICE & Interior
14
08-19-2020 01:49 PM
nsfx
10
05-19-2010 04:14 PM
chaseonbass
05-22-2009 03:12 PM
Starek_xB
11-19-2007 10:20 PM
Quick Reply: Scion iM Hardwiring Dashcam
