Scion iQ Drivetrain & Power Engine and transmission discussions...
Help with my 2016 Scion..Won't Start...
Old Oct 27, 2021 | 09:42 PM
water's Avatar
Exclamation Help with my 2016 Scion..Won't Start...
Hi, just came to the forums to see if anyone has any help regarding my issue.
I recently took my car to the dealer for an oil change, after getting it back 2 days later (today) i went to start my car & right when it cranked and went to start it completely turned off.
The gauges that move when you first turn on the car stopped mid way and now I cant do anything the car is not responding to anything at all.
Any help would be appreciated. Could it be the Immobilizer ? Dead battery ?
Important: Also in my fuse box there is some weird double fuse plugged in with a wire grounding the the bottom of the battery & 2 ends with electric tape hanging free all connected to the double "10" fuse plugged in
EDIT: tried jumping it with 3 cars. When the spark plugs are plugged into just my battery the other end has sparks if touched so it has juice ?
___
Old Oct 29, 2021 | 02:34 PM
DannoXYZ's Avatar
Moderator
Moderator
1. measure battery voltage with everything off. Voltage = ???
2. measure battery voltage with key ON. Voltage = ???
3. measure battery voltage while cranking. Voltage = ???
4. measure battery voltage at idle. Voltage = ???
5. measure battery voltage at 3000rpms. Voltage = ???
Those 5 numbers will tell you everything you need to know to fix problem permanently.
Also post video of how you're doing this spark-plug test connected to battery? thx
BenEv1l
Sep 5, 2019 01:58 PM
htony2323
Oct 28, 2016 01:57 PM
Kaeon
Scion tC 1G ICE & Interior
13
Feb 16, 2009 10:12 PM
TrueSlide
May 22, 2007 11:17 AM
JohnathonSull
Oct 2, 2006 07:31 PM
