Installing a Second Fuse Box?
Old Sep 14, 2006 | 03:32 AM
JohnathonSull's Avatar
Default Installing a Second Fuse Box?
I am planning on installing a second fuse box and placing under the driver seat. I will then run my amps, subs and cathodes through that. Then from there to a separate battery that will be mounted in the back someplace.
Anybody ever done anything like this? I don't know where I can get a fuse box at or what's involved with getting it wired up.
Any help would be appreciated.
__________________
Old Sep 14, 2006 | 04:17 AM
kzhorse's Avatar
Strictly Scionized
First think of a battery isolator that way it will charge when running and shut off when the power gets to low allowing enough power to start the car.
http://www.pplmotorhomes.com/parts/r...y-isolator.htm
here are some fuse blocks just do a search there are alot out there.
http://www.wiringproducts.com/dept_136.html
http://www.universal-radio.com/catalog/misc/3252.html
http://www.electroauto.com/catalog/elec.shtml
Scott
Old Sep 14, 2006 | 04:36 AM
I am installing a secon battery in the back of the car. so if it gets low it won't matter my main battery will still be able to start the car ( unless I am mistakin and this setup won't work ). I will still look at the battery isolator though, always nice to have jus incase...
Old Sep 14, 2006 | 04:48 AM
kzhorse's Avatar
Strictly Scionized
If you run the batterys in parallel it will draw from both and kill them both unless you catch it in time.
Scott
Old Sep 14, 2006 | 07:46 AM
HondAudio's Avatar
You *are* planning on upgrading your alternator in case you're charging both batteries at once, right?
Old Sep 30, 2006 | 09:31 PM
Hmm, I never thought of upgrading... Good point. For now I've had to shelve the idea, not enough money with christmas coming.
Old Oct 2, 2006 | 06:14 PM
saylor's Avatar
search for "30A power DIY cheap"
I did this - I have a box under my driver seat, just like what you are saying...
- Saylor
Old Oct 2, 2006 | 07:31 PM
ok sweet i'll check it out. thanks!
Kong
101
May 10, 2020 02:23 AM
htony2323
Oct 28, 2016 01:57 PM
icestorm
Scion tC 1G ICE & Interior
Jan 15, 2012 03:25 PM
buickid
Jul 10, 2009 10:29 PM
Kaeon
13
Feb 16, 2009 10:12 PM
