Scion iQ Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Brake pad upgrade
Old Aug 18, 2022 | 08:44 AM
EvilSink's Avatar
Default Brake pad upgrade
Hi!
next year im taking my IQ to a track. I want better pads, as im not sure if OEM pads would be able to take the abuse.
i have a 2009/2010 1.0 and there are only OEM replacements available when i search for pads using my VIN. But if i search for 2011 models and up there are a ton of alternatives. Are there any differences in the front brakes for the different models and model years? Would i be able to use pads from a newer model on mine?
i am also on the lookout for steel braided brake hoses.
any help is greatly appreciated!
Old Aug 18, 2022 | 03:57 PM
drizzoh's Avatar
Look up the part number for the pads that fit your year, then compare with the part number for the 2011+ and see if it's the same. Toyota doesn't change their brakes that often, chances are they're the same as what's on something else and there will be an upgrade available (same for the lines). That said, I really like Powerstop Z23/Z36 pads if you can find some that fit your calipers.
Also I'd recommend ATE TYP 200 fluid. Fantastic value and great boiling point.
Old Aug 18, 2022 | 11:19 PM
EvilSink's Avatar
Thats what i ended up doing, i called up the stealership i used to work at and found out all the part numbers for the front brake pads and rotors are the same from 2008 until 2014 in Toyotas part catalogue. Only 2015 was slightly off, perhaps its just a compound change but i am gonna stick to searching using the 2014 model Scion/Toyota IQ to be safe. Perhaps someone will weigh in with more information in the future
Old Aug 24, 2022 | 01:37 AM
Bugsgon's Avatar
I like the Akebono pads as scotty on you tube says. https://akebonobrakes.com/performance-street
cincinfocal
15
Oct 21, 2009 05:24 AM
flint_08
18
Sep 22, 2009 04:21 PM
poonertc
May 20, 2009 05:37 PM
jamessicat25
Aug 25, 2008 07:15 PM
Xangel83z
Sep 24, 2006 05:46 PM
