2008 tC Fog Light issues..
Old Jul 8, 2011 | 01:31 AM
JLW2008tC's Avatar
Default 2008 tC Fog Light issues..
I have a 2008 tC and I cannot figure out what is wrong with the fog lights. They are factory... any suggestions of what I should try?
Old Jul 8, 2011 | 02:02 AM
Jon's Avatar
Jon
Moderator
Moderator
With out a story or symptoms I'm not sure how we're supposed to help. If they're not turning on, then it's an electrical problem. It could be a fuse, the relay, or a loose connection.
Old Jul 8, 2011 | 11:05 PM
JLW2008tC's Avatar
well.. when I push the fog light button nothing happens.. bulbs are good.. fuses are good.. connections are good..
Old Jul 12, 2011 | 04:44 AM
Igotthatzumzum's Avatar
How about adding what you have done so far to ensure all this is good? Did you check power and grounds to the bulbs? My guess is that if you have checked all these, the ground that is for the fog lights is disconnected from the chassis...
Old Jul 12, 2011 | 04:52 PM
Lil_Deuce_tCoupe's Avatar
May sound simple, but are your high beams on? Fogs only work work with low beams - if your headlight switch is on high beam, the fogs won't come on. Make sure they are on low, then try the fogs.
If that's not it, then you'll need to keep checking....
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
