Aftermarket headlights imperfection or defect???
Originally Posted by NeveNelEstate
sure its not the position of the camera??
Originally Posted by magyver
yes, they are junk headlights..
Can any owner of these headlights check out your leds and see if it does have the same problem?
glad your happy w/ bottom of the line hot spotted crappy cutoff projectors.. but as long as you think there the $hit, more power to ya!
Originally Posted by Noodle
Originally Posted by Papispico
my little LED lights there are equal brightness...urs are messed up somehow...
NOodle where u from? i plan on baking mine also...
Who's gonna see em while you are driving? Well, YOU will. With the cutoff as aweful as they are in these, light is not going where it should for proper lighting of the road. These things really should be pulled off the market as a safety hazard....[/quote]
Ha! it's funny how you state that the lights do not go where it should be. I drive in the dark suburb and could see fine. I had both the stock and these lights, and I have to say that these lights produce more light output than the stock (from a driver perspective). May be you just need glasses.....
jk...
sorry if im a bit off topic but i got these headlights and everything was easy to install except for the angels and the 2 leds on the side, theres black wires and white wires, where am i supposed to connect them to????
I figure out why it is like this. The left head lamp do not have a chrome piece in the corner. so, the lights were not able to alluminate like the other lamp. Problem identified. Now I just need to open it up and carefully wrap a small piece of foil paper in the corner so the lights can alluminate.
ok are the leds that came with the lights blue or did it come with amber?
( i own a set of these and just havnt plugged up those yet, btw...my cutoff is almost straight...i screw arounded inside)
