Aftermarket mirror electrial help
So I just got some new m3 style power mirrors w/LED turn signals and parking lights, and I installed them ok, but my issue is that when it comes to the electrical, there's more wires now then there were with the stock mirrors.
I can prob just rip the door panel off and figure it out but I was wondering if anyone has installed these mirrors already and knows how to do the wiring. If you have pics of your wiring or if you could just explain it here that'd be a big help.
um.. nope. i havent seen a single tc w/ the mirrors you speak of.. not a fan of them. and not realy a point IMHO...
but i've actualy put these into a lancer.. never again.. but you have to match all the wires and its not fun. but your still gonna hve to run an extra power wire for the parking led's..
personaly, i would throw them out. they are cheaply made and you will burn out the led's and what not.. my buddy went through 3 pair.. plus, they are available for every make.. so there very unoriginal..
understood, i got them because some dick smashed my passenger side mirror (along with everyone elses side mirror on the entire street) and I didn't feel like paying $200 for a replacement.
Point being, i have seen pics of other people with them installed on here, so SOMEBODY knows how to do it, and before I waste time doing trial and error I was hoping maybe someone could explain.
The same exact thing happend to my passenger mirror and I saw that those m3 mirrors were $60 on ebay for 2 where as a new oem mirror was 150 shipped. I took the cheap route and had the mirrors on for 2 weeks until I decided they really looked cheap. I was so happy to get my stock mirrors back on I can't even tell you. They are far superior to the m3 ebay mirrors. With that said...there are 3 wires that come out of the m3 mirrors. The black is the ground wire and the blue goes to the blue leds inside and the white goes to the amber leds inside. Let me tell you the blue looks really rice but to each their own. From the stock side there is a greyish wire and a green( orange? sry im colorblind) wire. I forget which is ground and which is the light but just play around with it until you see it blink. The other 3 wires from the stock harness are for the motor. I believe the colors are black, white, and red, so that should narrow down the colors u need to hook to the mirrors. Hope this helps. And again I'll reiterate, you get what you pay for. In my opinion it makes the car look cheap.
Yeah, those are them. The issue is -
Stock mirrors have a plug with 6 wires in it, i'm assuming they go as follows -
1. 4 total for the mirror motor - 2 Up/Down + 2 Left/Right
2. 2 for the LED's (+/-)
The after market ones have a plug with 4 wires in it, which I'm assuming is for the mirror motor.
Then there are 4 separate wires for the LED's, 2 for the turn signal, and 2 for the parking light.
What I need to know is this - for the stock wires, what color does what? Which ones are for the turn signal and which ones are for the up down / left right?
Obviously i will have to run new wires and bridge them from my parking lights in order to get the parking light LED's working, but for now all im really concerned with is getting the mirror and turn signal power working.
Originally Posted by JQ
what are these mirrors you speak of? I must see, post pic or link or both.
Sounds good. Most likely i will be working on this early next week, if I can get it all working I will post a complete install guide for everyone. Again, if anyone HAS already done the wiring and can explain / has a pic it would be greatly appreciated.
Ok so the stock wires are like this -
My mistake there are 5, red, brown, blue, white, and green.
The new mirrors have this -
White, Blue, Black, Brown, i'm assuming these are the motor wires.
and they have this -
White, Black, Blue, Yellow, which I'm assuming are for the lights.
Again, if anybody knows how this works exactly it'd be much appreciated, otherwise I'm doin trial and error on my own early next week.
Ok, so I messed around with this and I finally have it working on the one side, power adjustment, lights and all. The only thing I didn't get around to was getting the parking LED's running cuz after messing with everything else I had no desire to mess with it anymore. I will finish the other side and post a guide for everyone as soon as im done.
ok so i finish putting these on last night, but i had to cut the stock mirrors wiering plug. the reason why is cuse i needed the black plastick on the stock mirorirs. well on the stock wiering plug you have 5 wiers orange, pink, white, black and red. orange is positive and pink is negative for the leds. ok well heres were it got complicated cause on the driver side i put white from the stock to white from the mirrors, black with yellow, red wjth green, and it work fine up down and side to side. but on the passanger side i did the same but up is down and down is up,but side to side works. ok so i started changing them but if i got it to work up and down side to side didnt or if i got side to side up and down didnt work or some times i only got side to side or only up and down. i changed them and change them but couldnt get the right order so i left it like i had it the first time. sorry no pic just after the install, well hope it helps.
