ARRRRGH why won't my passenger side HID's illuminate? HELP!
Old Jan 30, 2007 | 05:21 PM
BeetC's Avatar
1UP Crew
Default ARRRRGH why won't my passenger side HID's illuminate? HELP!
Finally putting some HID's on the tC....I go to install them and the driver's side works fine, but the passenger's side refuses to illuminate. I switched out both ballasts and both bulbs to the driver's side, and they all work. The passenger's side will still light up a normal halogen bulbs (Sylvania Silverstar if it matters) but it won't light off my HID. I've tried using conductive gel and splicing a new connector on, with the same result. Halogens on both sides work, HID's on the passenger side do not. No fuses blown, ballasts are good, bulbs are good, connections are good, but the passenger side is just fighting the mod :D What do I do?
Old Jan 30, 2007 | 05:28 PM
Dakine's Avatar
Concept in Motion Crew
Are you running a wiring harness?
Old Jan 30, 2007 | 05:57 PM
Guru's Avatar
Does it have separate ground? If so check the ground.
Old Jan 30, 2007 | 05:59 PM
Neothin's Avatar
that's what i was thinking guru. my HID's in the fogs didnt work until i sanded off paint and such.
Old Jan 30, 2007 | 07:39 PM
JaN_MiChAeL_07's Avatar
what kind of HID's did you get ?? call the company ...
Old Jan 30, 2007 | 07:48 PM
equinox2355's Avatar
try the pass side setup with the driver side connection, and if it lights then it has something to do with how its connected, if it doesnt, then atleast one of the components on the pass side hid setup is bad.
Old Jan 30, 2007 | 09:39 PM
BeetC's Avatar
1UP Crew
The setup doesn't have a separate ground, I'm not running relays (just PnP for now) and
I did. I did both ballasts and both bulbs and all possible combinations thereof, and they always lit, but only on the driver side. However, both sides will still light regular halogen bulbs. So basically, it's not the ballasts, because they both work. It's not the bulbs, because they both still light. It's not the car's wiring because it will still light a normal halogen bulb. I'm beginning to get quite frustrated....
Old Jan 30, 2007 | 11:10 PM
aznpimp's Avatar
do you have a tcs friend who can help you with ? or find relatives that have 9006 low beam and try.
Your problem sounds like mine. When I got the car back from body shop. put back kit, but the passenger didnt light up. So I switched the wiring from the bulb connected with the stock harness on that side only, it worked ! Give it another shot man
Old Jan 30, 2007 | 11:19 PM
N-Dawg's Avatar
I had a similar problem to yours and I found that The OEM plug wouldn't go all the way in to the Ballast. My kit came with a harness that connects to the OEM female plug. I cut some of the plastic casing from the relay narnesses male connector so it fits into the OEM female Plug. I found out this was the problem after I had all my connections secure and my halogens were working with the OEM plugs, check it out, this might be it.
Old Jan 30, 2007 | 11:25 PM
BeetC's Avatar
1UP Crew
I tried that, and for a while thought it was the problem. Instead of trimming things, I just went out and got another 9006 female end at the auto parts store, cut off the car's existing female end and connected the female I bought. I added some conductive gel too while I was in there. Now the plug sits firmly into the male end, and I know for a fact that the type of connector works with this kit because the BMW has the same type of 9006 females and they worked perfectly for more than a year. End result? Still nothing.
I'll try putting the kit back on the BMW (or our Accord for that matter, which also uses 9006 lowbeams) tonight. I don't think it'll work, though. Would a relay harness help me? I really don't feel like dropping any more money on this...
Old Jan 30, 2007 | 11:32 PM
N-Dawg's Avatar
the harness might help because it voids the entire passenger side OEM connector and turns on with the signal from the driver side.
aznpimp's Avatar
yah, keep us updated .. Im wondering what causing it not light up ..
Old Jan 30, 2007 | 11:33 PM
N-Dawg's Avatar
Cliffud sells the harness for like 30 bucks, check him out in the sponsored sale section. Plus, running your ballast without a relay harness is asking for trouble.
Old Jan 30, 2007 | 11:36 PM
BeetC's Avatar
1UP Crew
Could I make one for cheaper? I don't feel like blowing 30 bucks on something I can make for less, plus I want to get these working ASAP.
Old Jan 30, 2007 | 11:42 PM
N-Dawg's Avatar
Maybe, but I don't know how to make it exactly. Here is a pic of it. I know Cliff ships them out the same day he gets paid so don't wohttps://www.scionlife.com/forums/viewtopic.php?t=152060&postdays=0&postorder=asc&&start=40rry about waiting, plus they are good quality harnesses.
Old Jan 31, 2007 | 12:15 AM
BeetC's Avatar
1UP Crew
Link doesn't work...?
Anyway, does anyone have a schematic or diagram that I can use to make a relay harness?
Old Jan 31, 2007 | 12:23 AM
djpax's Avatar
https://www.scionlife.com/forums/vie...=asc&&start=40
Old Jan 31, 2007 | 12:27 AM
aznpimp's Avatar
hey Robb, try this link
https://www.scionlife.com/forums/vie...gram&&start=20
hope that helps man ..
Old Jan 31, 2007 | 12:57 AM
BeetC's Avatar
1UP Crew
Thanks Duc!! I'll check it out.
Old Jan 31, 2007 | 02:11 AM
raWr215's Avatar
make your own wire harness ^^, always works better. Use gold rings please, going cheap will rust and it'll get stuck XD
