Caliper painting
Old Nov 25, 2009 | 12:25 PM
RichTc's Avatar
Default Caliper painting
I am about to paint my calipers (for the second time) and wanted to see if anyone had any suggestions on paint. Last time I used 500 degree engine enamel, but a year later it has faded and chipped (could be poor prep). Would the brush on caliper paint be more durable?
Old Nov 25, 2009 | 01:15 PM
rangerryda's Avatar
Brush on caliper paint kit from Autozone works like a charm.
Old Nov 25, 2009 | 01:27 PM
MeatRocket's Avatar
probably the most important thing is prep work. make sure everything is clean and degreased, that way the paint will stick. and give it pleanty of drying time.
Old Nov 25, 2009 | 05:45 PM
RichTc's Avatar
I ended up the G2 kit.
I am doing this in midst a rotor/pad change and was concerned that the heat cycling to break in the pads would affect the paint. So, this stuff is a two part epoxy and is supposed to hold up to 1000 degrees.
Hopefully I won't have to do this again.
Old Nov 25, 2009 | 05:49 PM
JBT89's Avatar
i primered n painted them white but i used high heat paint rated at 2000degree for both paint n primer... but like the rocket said make sure evrytin is clean n make sure u give a few hours of drying time...
Old Nov 26, 2009 | 03:47 AM
rangerryda's Avatar
There are many correct ways of doing this, the easy slap the paint on after a little degreasing and taping worked for the past 3 cars I've done. All three have well over a year and are still shiny here in salty air Florida. Mine shine right up with a wet rag while washing the car.
rvascion
Nov 12, 2020 03:23 AM
jeremydoc
Sep 16, 2015 11:31 PM
mc1114
Scion tC 1G Aero & Exterior
Aug 10, 2015 10:34 AM
gqdabien
Jul 22, 2015 10:30 PM
nightwitch
Jul 14, 2015 01:58 AM
