Carbon Hatch Problems!
Old Feb 21, 2010 | 02:39 AM
deez's Avatar
Default Carbon Hatch Problems!
So I just bought a carbon hatch that was slightly used from someone on this forum, a few little things with it but overall it's in pretty good condition. Install didn't seam bad. I left the shocks on it that the other kid used. I left his mounts on the shocks too. He said they came off of a celica. The shocks don't hold the hatch on but no big deal I can buy new ones, the problem I'm having is the hatch won't close all the way or something. It latches and all but the glass nor the carbon lid fit flush with the sides of the car. They stick up any help or suggestions? Anybody know the correct shocks to use also?!
Old Feb 21, 2010 | 03:27 AM
RoboCop's Avatar
Are you using shocks? I know many people take off the shocks because it pushes the hatch up with the lighter carbon fiber hatch compared to stock.
Old Feb 21, 2010 | 03:31 AM
ack154's Avatar
They stuck up b/c the shocks are rated too high.. like RoboCop is saying. You need lighter PSI shocks for the lighter hatch.
Old Feb 21, 2010 | 03:56 AM
deez's Avatar
I have different shocks, they're too light, it doesn't even hold the hatch up in the air, but im wondering if I should just remove them, maybe glass wont stick up?
Old Feb 21, 2010 | 08:13 PM
deez's Avatar
Any help Would be appreciated.
Old Feb 22, 2010 | 12:36 AM
Kanchi's Avatar
take them off and see if it closes, worst case scenario you just put them back on.
Old Feb 22, 2010 | 05:27 AM
deez's Avatar
Well, tonight I took the shocks off all together, still no good. Maybe adding washers under the four bolts that bolt it to the car, above the rear window?
Old Feb 22, 2010 | 10:44 PM
deez's Avatar
Default Re: Carbon Hatch Problems!
Anybody else? The hatch is seibon.
Old Feb 23, 2010 | 12:42 AM
scion71tc's Avatar
Both mine and my friend's carbon fiber hatches don't fit perfect. The glass barely sticks up past the body but it's not that noticable. Post up a pic if you can.
Old Mar 24, 2010 | 06:01 AM
deez's Avatar
It's hard to tell I gotta get to the shop where my car is and take pics.
Old Mar 24, 2010 | 06:02 AM
deez's Avatar
And another pic.
Old Mar 24, 2010 | 07:20 AM
scion71tc's Avatar
Looks just like mine from what I can see.
Old Mar 24, 2010 | 10:38 AM
deez's Avatar
Is that good or bad? Lol. I added washers under the bolts where it bolts to the car above the rear glass. The passenger side got worse and stuck up even more and then drivers side got better and say more flush. Added the same amount of washers all around.. So weird.
Old Mar 24, 2010 | 10:12 PM
scion71tc's Avatar
Carbon fiber usually doesn't fit like oem. I just forget about it. I've seen worse fitting carbon fiber parts on other cars lol
Old Mar 24, 2010 | 11:27 PM
deez's Avatar
Yeah as long as it doesn't let water in I guess. As for a hood what should I do? I also was wondering should I get the same brand hood as the hatch?
Old Mar 25, 2010 | 06:13 AM
scion71tc's Avatar
I have a VIS hatch and Seibon hood. They look the same
Old Mar 25, 2010 | 06:24 AM
05carbontc's Avatar
i have carbon creations cf hood and fenders and they fit good i think, the hood is level with the fenders but their is a gap between them that is bigger than what the oem parts had... check it out i just put a pic up, in new post i started a thread called "newb checking inn" scroll down and youll see it.
Old Mar 26, 2010 | 01:07 AM
Frizz's Avatar
Team ScionTific
I think VIS is rubbish
Old Mar 26, 2010 | 04:54 AM
deez's Avatar
So go with the seibon hood too?
Old Mar 26, 2010 | 08:29 PM
toeveryhour's Avatar
it really doesn't matter which brand hood you go with. go with a style you like and check around and do your homework to see if people are experiencing problems with fitment.
i have a VIS hatch and a kaminari hood btw
