Changed the light setup of headlights...
So, I purchased some white LED parking lights and installed them...since the stock bulbs give off a yellow color and interfere w/ my Supa White low-beams...so since the LED's are white they match pretty well now....Then I also just took the bulb outta where the amber corner lights up...so that makes the entire healight set-up look Hella TIGHT at night...Ok, just thought I share, if anybody has a similar story they care 2 share...Go for it!
Originally Posted by engifineer
The leds will stop working soon. You will want to keep an extra set. The LEDs in those are not made for the heat inside the housing. Just an FYI
Ok, was lazy but here are some pictures...Kinda crappy due to the bad camera I used but yea..Enjoy!
Healight w/o the light on behind the amber corner..I just took out the bulb
The white LED bulb..if u can see it..lol
If you're dead set on keeping white LED's in the headlight housing, try www.superbrightleds.com. The 6-bulb cluster 194's are pretty bright, so are the directed cluster 194's. Should do you better than those. I had a pair of 'tuner shop' inverted cone LED's in my headlights for a while, and they were never bright enough.
Of course, if you want bright, go with PIAA 194 bulbs. I get flashed occasionally by people who think I'm driving around with my headlights on during the day. Which is fine by me, I drive with my parking lights on for safety anyway--just means it's working.
you want the white 194 5 led from superbright.. they have 5 leds, one in every direction and one giant one facing outwards.. thats what you want for most coverage.. its what i have.. pimp... dont buy bulbs from pepboys.. just get all your factory replacement led bulbs from superbright.. super cheap and low shipping and it will be there in 2 days
and besides.. the reason why we can't have clear corners.. is also the reason why it's not a good idea not to have a bulb in there.
Originally Posted by CA V.C.
Section 25100. (a) Except as provided in subdivisions (b) and (d), every vehicle 80 inches or more in overall width shall be equipped during darkness as follows:
(1) At least one amber clearance lamp on each side mounted on a forward-facing portion of the vehicle and visible from the front and at least one red clearance lamp at each side mounted on a rearward-facing portion of the vehicle and visible from the rear.
(2) At least one amber side-marker lamp on each side near the front and at least one red side-marker lamp on each side near the rear.
its a mod, if everyone did everything legaly, i think this site would be hard pressed to stay in existance... pretty much everything you do is illegal now.. but its a hobby.. we do it cause we like it... dont sweat the small stuff, and this is so so small.. LOL... my .02
What exactly do you mean broken??.....haha.....What about all them people that use them black over lays to cover up the amber reflector piece??.....All I did was take out the bulb and the ugly amber reflector is still like stock!!...Oh well I guess I am a "bad" mod-er...haha
