Convert signal lights to parking lights.
Subscribe
Apr 11, 2008 | 06:12 AM
I was wondering if anyone had done this. My girl has an accord and like a bunch of new cars now-a-days, she has running daylights. I was just wondering if anyone had ever made their signal lights on the tc, which i love, into running daylights or parking lights that can be controlled with the switch, i think it would look pretty cool since those lights are so bright and nicely placed. they would also have to keep their service as a signal light of course, but i've seen a lot of cars, including many toyota's i think have this feature. I'm curious to see how its done, i don't think it would be very complicated to do, i just dont want to experiment, if you catch my drift. Trial and error is not a method i like to try on expensive stuff. thanks.
Reply
Apr 11, 2008 | 02:27 PM
http://www.hamsar.com/drlkits.htm
Make your high beams day time running lights...i looked into this before but it would be pointless after i retro my HB
Reply
Apr 11, 2008 | 10:06 PM
thats interesting. and theyll still work as high beams when i need them?
Reply
Apr 11, 2008 | 10:18 PM
would these bulbs work for us?
http://autolumination.com/switchback.html
Reply
Apr 11, 2008 | 10:33 PM
Yes, but you'd have to wire in an additional 12v source. Our turns only have one postive, one negative.
You need a 5 pin relay to get the stock ones to do this.
Off the top of my head, the hookup would be:
85: + from turn signal switch
86: ground
30: + to ign source (on when the ign is on)
87a: + to turn signal bulb
87: not used
This would make the light be on when the car is on and blink on and off when you hit the turn signals.
You'd need one for each side, and you may need a LED (Heavy Duty) flasher unit to get rid of the 'hyperflashing'
Reply
Apr 12, 2008 | 06:10 AM
is there a "how to" on how to wire in a relay?
Reply
Apr 12, 2008 | 04:23 PM
I haven't searched, I'm sure there is, but it's really not that hard. The relay will have 5 connectors (make sure you get 5-pin relays) with the numbers I posted above. Just make the appropriate connections and you're good to go.
If you're not comfortable doing it yourself, anyone that has done car audio or alarm installs will know how to do this.
Reply
Apr 12, 2008 | 05:07 PM
i've read how a relay works which makes me wanna go and buy a whole bunch of relays. i've stripped and connected my entire audio system at home but yea, i am a little hesitant. i'll visit my neighborhood ar audio place and ask one of the installers.
Reply
Apr 12, 2008 | 05:38 PM
Quote: thats interesting. and theyll still work as high beams when i need them?
yes
Reply
Apr 12, 2008 | 07:47 PM
Check it out. I've been thinking about the brake light pulser.
http://www.webelectricproducts.com/products.htm
click on Daytime Runnling Lamps and go to the bottom of the page for the Universal kit.
Reply
Apr 12, 2008 | 08:52 PM
yeah the BLP looks interesting. i've seen some cars with it. wouldn't mind getting one.
Reply
Apr 13, 2008 | 03:41 AM
i've seen ambulances with that. no cars though.
Reply
Apr 15, 2008 | 08:13 PM
Tap the power from your paking light..
Then tap it to your turn signal wire with one way diode .. and it's done.....
Reply
Apr 15, 2008 | 10:52 PM
^^ Except when you have your parking lights on and you hit the turn signal; nothing will happen cause the bulb will alway have 12v power.
Reply
Apr 15, 2008 | 11:01 PM
Quote: ^^ Except when you have your parking lights on and you hit the turn signal; nothing will happen cause the bulb will alway have 12v power.
Oh yea.. forgot to add the resistor to dim it down..... LOL
Reply
Apr 16, 2008 | 03:12 AM
so...no relay required?
Reply
Apr 16, 2008 | 03:26 AM
Quote: so...no relay required?
There is few differnet ways....
Without relay, just tap the power from the parking lith.. inline with resistor(reduce the brightess) and one way diode...
Wihtout relay, using 1157 bulb and harness... just tap the power from parking for dim light and bright from stock wire
With relay,,, you can have it so that.. it will turn on with parking light on...
Then turn off when turn signal is on.....
Reply
Apr 16, 2008 | 03:30 AM
hmm....interesting. don't suppose there's walkthrough on it.
Reply
Apr 16, 2008 | 03:55 AM
Quote: hmm....interesting. don't suppose there's walkthrough on it.
Sorry,, no.. that is just the guide line... you have to figure out the rest...
Reply
Apr 16, 2008 | 05:37 AM
Like anything electrical, there's a million ways to do it.
Reply
