does anyone know how toooooo.....
install the rs1 lipkit? like the sides and everything? i just recieved mine today and im clueless on what to do... i know i use double sided tape to put it on but i need advice or some diy
The sides are the easy part.......clean the stock skirts with alcohol and on the lip kit I installed a couple of weeks back we used two layers or 3M tape and just stuck it on.....pull a good foot of the backing off so when you have the lip in place you can pull the rest of the backing from behind off and push it all into place.Screw the ends into place and good to go..
Same with the front and back.....it is an easy kit to install......make sure you have a firend or two there to help get it all on straight and you will be fine.
