figure llc grill installation help
Well, I installed the grills today, they look good, but the top grill I have a problem. Where did you guys drill the holes for the bottom part of the top grill? Did you drill them on those tabs stickin out? Cuz I did, and it looks like the bottom part is getting pulled in too much. I'm going to have to redo it most likely.
If you are confused about which tabs to drill into, first line the grill up. Look inside and see which tabs the grill line up with best. Align the grill just how you like it and put the ties on loosly at first. Tighten them each little by little until you can't move them at all and they are tight against the grille and fender. They are Dope Grilles....
yup drill in the tabs...make sure when tou drill into the tabs all of them must be about the same length from the edge or it will be a little off. and when you put in the zip ties don't tighten them. b/c you have to play around with the fitment. you won't regret the grille!!!
minter66
Dec 15, 2014 01:45 PM
randomsuper
Dec 5, 2014 11:14 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
