Fog light problem
Okay so I just bought some VRD fogs and it already has the harness mod so they run without the headlights on. However the fog lights will not turn on! The switch has power. The relay is clicking. And the wires are connected right. Where is the fog light fuse? Also, the green/grey wires should be spliced together correct? Thanks in advance!
I've searched for hours with no help.
Make sure your high beams are not on - fogs only work when low beams are on. I went through the same thing before, didn't realize I left the high beams on when I shut the car off the night before.
Its grounded on on the same ground the headlight uses. But its between the washer and nut that my CAI uses as a mount. Would that be a problem? Should I use a ground directly to the frame?
Simple enough to check - do you have a test light? Attach the lead on the test light to the bolt you're using as the ground, and touch the light probe to the + terminal on the battery. If it's a good ground, you'll have a light - if it's not, you won't.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
