Front ad rear lip mounting ?
I have a front and rear lip that I want to install. I wanted to know what people use to install them a nut and bolt or just a screw rIght into the bumper along with double sided tape
what lip is it...do you know? i have the rs1 full lip kit from racing solution...i used double sided tape where it came in contact with the bumper and then put a couple of screws on each side in the wheel wells. hope that helps
It's the eBay knock off so I would do what you did the screws just went into the oem bumper there not loose or anything figured I need a nut or something to keep it tight
