Front parking light
I'm about to buy some super white leds for my front parking lights from this site:
http://tinyurl.com/34nh9ew
There's a couple that are 194s and wanted to know which you guys recommended.
i'd recommend these since you have an 08+ headlights, they're bright and would look perfect if you have 6k and 8k HIDs.
http://www.buyheadlightbulbs.com/Cir...p/cir-3101.htm
http://store.garage1217.com/insane-1...edg194168.html
^You can try those.
I'm running Pilot 194 White LEDs and had to replace one a few months later as it was defective and no longer lit up. A trip to Autozone(or was it Advance AutoParts?) and switched the pair for a new set. 1 year defective replacement in store no problem at all, one advantage of getting something at a local store. So far all is good.
^You can try those.
they're worth it, my gf has an 08 and i bought her a few LEDs from autolumination.com and they would burn out. now these have been on the car for almost a year and haven't had a problem with them flickering or dimming which is better than having to keep buying LEDs over and over.
yeah then they're worth it...just sayin i got all my LED's off ebay and spent under 10 bucks for my whole interior/exterior on my old tC which was 3 years ago. got my new tC last summer and transferred em onto it and they're still goin strong!
yes they are, they've been on the car for almost a year and before that i would order a few different type of LEDs from autolumination.com as well as the ones with heatsink on them just so they would burn out all at once or 1 LED at a time. yes the car is driven early in the morning to work when the sun is still down and also at night so the low beams are pretty much always on. if you want to see pics lmk so i can go take some to post up and show you
^Are you running HIDs for the low beams? With the 08-up headlamps being projectors I don't think heat would be an issue running just the lows. I haven't had a need to run high beams much so can't say much there. Besides having a defective LED, the Pilot 194 White has been holding up well.
It's hard to get a decent pic of LED parking lights without glare. It's just something you'll have to go on and just install. I know with mine I've had some people mistake them for halos/angel eyes around the high beams.
Thanks for the pics aciddrop. They look good.
I just received my leds and got one side installed but the other side is tough as hell. There's no room to put all my strength in there. I will give it another go tomorrow.
^Happened to me too. The bulbs are tough to take out the housing the first time, after that initial removal it's easier to work with. Which lights did you go with?
I forgot I had a pic in the online garage
https://www.scionlife.com/forums/pic...pictureid=4272
LED packaging
https://www.scionlife.com/forums/pic...pictureid=4271
LED packaging
thats exactly what i had on mine...only thing is that i got my LEDs from superbrightleds.com
and at first the drivers side was hard but i got it after two trys...just need to get it at the right angle
