help with spoiler uninstall,pls
Old Jun 6, 2007 | 07:47 AM
iamalmighty123's Avatar
Default help with spoiler uninstall,pls
Hi i would like to know how to take my spoiler off my tc.. i would be really appreciate it if someone can help me with this. it would be helpful if you can post pics too.. thanks in advance
Old Jun 6, 2007 | 08:21 AM
SquallLHeart's Avatar
- remove two screws on the inside to tear apart rear plastic panel pieces ...
- remove nuts holding spoiler in....
- yank that SOB off...
- cry at your naked hatch with ugly holes.
Old Jun 6, 2007 | 08:37 AM
ZodtC's Avatar
is there any way that we can cover the holes? im tired of that stupid pedestal spoiler, is there only 2 holes for pedestal? do any of u think the lip spoiler can cover the old holes
Old Jun 6, 2007 | 02:39 PM
ryphlex's Avatar
Took mine off a while ago.
Go to TRDSPARKS.COM and look at the install template.
It will show you what panels in your trunk to pop-off to access
the holes needed to unbolt the bolts.
After those are off, you're gonna spend A LOT of time trying
to pry it off because of the super duper ownage tape holding
it in place. What I did was get a hair dryer and lift up as hard
as I could while blow drying it. This let the hot air go directly
into the adhesive causing it to be pliable again. It's still going
to be tough though. What I did was grab a knife, lift up the
spoiler as high as I could, and slice away at the adhesive
loosening up section by section.
Try your hardest not to put pressure on the spoiler going
downwards. There are going to be "indents/dents" in your
trunk on top where it used to sit because that part of
the car has no support under the metal.
And you're going to have 4 holes, not 2.
2 for each side.
Old Jun 6, 2007 | 02:43 PM
ack154's Avatar
Lip spoiler will likely not cover the holes. You'd have to have a body shop fill them and paint it.
laforze
12
Feb 16, 2016 12:50 AM
excb7
Jul 19, 2015 11:17 PM
carid
Jul 14, 2015 01:10 PM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 5, 2015 06:09 PM
