HELP!!! Taillights!!!
Old Mar 8, 2009 | 06:21 AM
scion09's Avatar
Default HELP!!! Taillights!!!
I replaced my tail lights and everything works except for my brake lights and running lights...my third brake light also doesn't work. I need advice on how to fix these. They are LED tail lights from e-Bay. (don't laugh) this is the exact face I made when my friend pressed my brake lights! So any advice or info given will be greatly appreciated.
Old Mar 8, 2009 | 06:26 AM
BlackMetal's Avatar
Default Re: HELP!!! Taillights!!!
First check to make sure the polarity is correct, if it is reversed chances are you blew a fuse... Check to see if the fuse is still ok, if it is check your wiring...
Old Mar 8, 2009 | 05:43 PM
kiss_kiss_kill's Avatar
Did you disconnect the battery when doing the install? If not....you blew a fuse.
Old Mar 8, 2009 | 06:12 PM
SW_08's Avatar
i call blown fuse
Old Mar 9, 2009 | 06:22 AM
scion09's Avatar
yea yea i forgot to do that stuff...so where do you locate the brake light fuse?
Old Mar 9, 2009 | 12:08 PM
SW_08's Avatar
i believe its a 10..
its under the dash driver's side by the hood release....
Btp907
Sep 11, 2015 11:46 PM
blue_xB_23
Mar 20, 2015 07:39 PM
Scion_XXXBoX
Oct 1, 2003 04:58 PM
