HID problem...help
Old Jan 31, 2007 | 10:56 PM
xezerax's Avatar
Default HID problem...help
ok i just installed my HIDs. i try to turn them on and nothing, just my DRLs. i double checked all my connections, i checked all 3 fuses on the wiring harness. i thought maybe i didnt have a good ground so i grounded to the battery and still nothing. also when grounding the to battery, when rubbing the ground against the battery should i get sparks? cuz there were none. anyone have any ideas?
Old Jan 31, 2007 | 11:38 PM
TurboC's Avatar
hmmm...... good luck. bulbs?
Old Jan 31, 2007 | 11:40 PM
fox's Avatar
fox
did you plug the HID harness into the factory harness?
Old Jan 31, 2007 | 11:41 PM
xezerax's Avatar
yes it is plugged into the harness i heard it click so i know its in all the way
Old Jan 31, 2007 | 11:45 PM
xezerax's Avatar
if i rub the power connection and the ground connection on the two battery terminals shouldnt i get a little sparkage? if not could it be the wiring harness?
Old Jan 31, 2007 | 11:46 PM
Stealth_Fighter_tC's Avatar
Dumb question, but did you happen to buy them new off a known website, or ebay, or a friend or something? Reason im asking is because a friend of mine bought a pair for a diffrent car, and was having the same problem, come to find out both bulbs were shot, replaced them and they worked fine! Might have blown during shipping or something! Just a thought.
Old Jan 31, 2007 | 11:48 PM
xezerax's Avatar
i got them from the sponsered sales section here, they have all good reviews so far and nothing bad, is there a way to tell if the bulbs are bad?
Old Jan 31, 2007 | 11:55 PM
gcxandy's Avatar
you should double check your connections again, the ones that connect the ballast to the bulbs, make sure each plug goes with the rigfht ones.
Old Feb 1, 2007 | 12:01 AM
xezerax's Avatar
before i installed these my driver side headlight was out. since that side is the one my wiring harness goes into im thinking maybe it is the fuse. does anyone know where the drivers side headlight fuse is located?
Old Feb 1, 2007 | 12:02 AM
Im not a 100% sure, the only way we could tell is buying a new pair of bulbs, sorta like process of elimination, and if that didnt work we were going to take them back. But I would think by looking at the bulb, sorta like a light bulb for a house or something, one of the prongs would be broke or something. I might be wrong, but im sure if I am, ill hear it in a few minutes Good Luck Let me know what you find out, incase I run into the same problem!
Old Feb 1, 2007 | 12:05 AM
TurboC's Avatar
its the bulbs......... i said that like 30 min ago.
Old Feb 1, 2007 | 12:10 AM
HeirAutomotive's Avatar
This is most likely the problems... Although I am unsure which fuse is for the headlight, You should spend some time pulling out each fuse to check if any fuse has blown. Also check the fuse that is located on the harness itself if it came with one.
If it turns out to be an issue with the stock wiring harness or bulb connector, get it fixed under warranty. Make sure you have the stock bulbs in when you bring it in. They probably will not warrenty it if they see bulbs other than stock installed.
Old Feb 1, 2007 | 12:15 AM
Yeah I was actually backing you up, I just forgot to add your quote.
Old Feb 1, 2007 | 12:18 AM
SSQ's Avatar
SSQ
what HID did you buy by the way?
Old Feb 1, 2007 | 12:19 AM
xezerax's Avatar
yea so its not the fuse...is there any way to tell if its the bulb by looking at it or maybe shaking it? dont really wanna buy two new bulbs for nothing..
Old Feb 1, 2007 | 12:20 AM
thats actually a good question!
Old Feb 1, 2007 | 12:23 AM
xezerax's Avatar
got it from https://www.scionlife.com/forums/viewtopic.php?t=157333
im not bad mouthing their products at all the shipping was extremly fast and customer service was good so far... ill play with it more tommorow when its light out hopefully i wont have to order new bulbs...
Old Feb 1, 2007 | 01:03 AM
SSQ's Avatar
SSQ
I see.
I ask because I also recently bought a set from this site.
This is a very very stupid question. Don't throw rocks at me. Have you flipped the socket from the original bulb to the power to ballast?
Old Feb 1, 2007 | 01:16 AM
xezerax's Avatar
I see.
yes i have... ok so i just went out in the dark and unplugged everything and plugged it all back in and now it works. something was prolly not in all the way and now i feel like a jerk. anyway the lights look great and i deff recomend this kit. i will be taking some pics later in the night.
Old Feb 1, 2007 | 01:19 AM
scionboi06's Avatar
Team Scionce
this should help reverse the pularuty swap the wires some tc headlights are reversed! it happen to me and i switched the wires and bingo!
