Hid trouble after some time.
Old May 25, 2012 | 06:53 AM
doper's Avatar
Default Hid trouble after some time.
Guys i had hid for quite some time. Last week my right went out so i was like ok ballast is done i went and replaced both since its still under waranty. Now right is out again wtf? I tryied to plug bulb in secon balast and it worked. 10 min later my left went out just all of the sudden . I waited like 2 min turned them on and left is working right is still out.
Anyone experienced this issue? The new ballasts are in car only 4 days.
Does tc have a wire isue or do i need switch the fuses to 15 or what i checked the fuses and they are fine . I have no idea what could cause this problem .
Thanks guys.
Old May 26, 2012 | 02:36 AM
doper's Avatar
No one? I was in idea over the years that there are some ppl on here who know stuf.
Old May 26, 2012 | 02:59 AM
Irishguy0224's Avatar
Im not sure what it is, BUT it is possible you have another set of bad ballast's, i have heard of people getting new ones that are bad.
Or.
You could simply have a bad wire somewhere as well.
Old May 26, 2012 | 03:11 AM
doper's Avatar
But where like prior to ballast? Its wierd that its again the stupid right side and interesting that left one turned of and on. Is tgere any way to test some stuff?
Old May 26, 2012 | 03:26 AM
doper's Avatar
Ok i just tried and switched the ballast from right to left and etc. Since it didnt work i am guessing its the ballast. My question now is why is it right side again? How is it with tc is there chance that more power is going to the right so it burn it or what could it be that is the right side again?
Old May 26, 2012 | 05:06 AM
doper's Avatar
Had to put regular in
Old May 26, 2012 | 05:07 AM
doper's Avatar
Idk wth is going on right side same issue not normal
Old May 28, 2012 | 01:27 AM
xA_flyby's Avatar
dude check ur fuses...samething happened to me and it was my fuses lol. so check ur fuses all of them in the engine bay box.
Old May 28, 2012 | 02:54 AM
testa422's Avatar
^unless im wrong, i would assume both headlights are on the same fuse. if not, thats some dumb planning by toyota
Old May 28, 2012 | 03:34 AM
xA_flyby's Avatar
there are different fuses. one for left and for right. size 15. atleast thats what it is for my xA.
Old May 28, 2012 | 06:22 PM
testa422's Avatar
oh well...i may be wrong!
Old May 29, 2012 | 04:13 PM
mxyooji's Avatar
each Low beam socket has a 10amp fuse, then to switch relay, then to a 30amp fuse, then to power source. totaling of 40a (10+10+30) main relay.
if u just got new ballasts, why not get a whole new kit / set of bulbs. so u know ur not taking a risk; u should've also just gotten new bulbs. lol
Old Jun 1, 2012 | 03:09 AM
doper's Avatar
I did i did get the whole new set. Not just ballast
Today i got another one so lets see how long will it last. What about fuse will changing 10 fuse to 15 make any differece?
Old Jun 5, 2012 | 12:07 PM
mxyooji's Avatar
No. You don't need to change the stock fuses that won't help bcuz the main relay is a 40amp relay and you basically could eff it up.
Sent from my I727 rocket on Marz! @_@
Old Jun 5, 2012 | 06:10 PM
doper's Avatar
Ya i put it back but it dont matter now i got the frs so yeah lol easy fix lol
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
mischman
Sep 15, 2015 03:38 PM
Threequalseven
Aug 26, 2015 04:24 PM
herbn44
Jul 24, 2015 02:26 PM
