HID'S ON STOCK TC HEADLIGHT HOUSING
Old Jan 19, 2006 | 05:23 AM
SO-CAL_TC's Avatar
Default HID'S ON STOCK TC HEADLIGHT HOUSING
Hey everyone. I have hid bulbs from a 2005 corvette but i was wondering if i could install just the bulbs instead of having to install the bulbs w/ the ballasts.
Old Jan 19, 2006 | 05:35 AM
WeDriveScions's Avatar
That is not possible... HID bulbs are a totally different setup than a standard stock setup and require the ballasts without question...
Sorry...
-WDS
Old Jan 19, 2006 | 05:44 AM
_-Dark-_-Scion-_'s Avatar
Sorry...
-WDS
yeppers.
Old Jan 19, 2006 | 06:08 AM
insanelyx's Avatar
okay.. i have a question about adding a HID conversion kit. ummmmm.. yeah. the only problem i really really want to do it. but. the jdm parts i might get are hb4 (9006) with the stock housing. how would it actually look like ? because i have seen mostly all HID STOCK lighting system out in the road with the blub filter thing on them ? would i need the light filter ? or just go straight blast ?
Old Jan 19, 2006 | 06:24 AM
tcholic's Avatar
sorry doesnt make sense at all......
Old Jan 19, 2006 | 06:29 AM
insanelyx's Avatar
sorry... late nite.....
okay. i want to add HID to my stock headlights. i'm gettin a 9000k HID conversion kit. now. if i were to add it to my headlights. how would it look ? would it be a full blast of HID or need a bulb filter like some of the new bmw's/lexus/etc ?
Old Jan 19, 2006 | 02:47 PM
ScionDad's Avatar
I have the 10000k Xetronic HID kit on my daughters tC and it's not blinding at all. The cutoff appears to be just fine. No glare head on as that was my biggest concern. Night vision is amazing and looks very classy head on.
Old Jan 19, 2006 | 03:31 PM
SO-CAL_TC's Avatar
so you want to basically do what i want to right? you wanna install straight hid light bulbs with out the ballasts
Old Jan 19, 2006 | 03:33 PM
SO-CAL_TC's Avatar
does she have projector headlights or stock headlights w just the bulb and no balast?
Old Jan 19, 2006 | 03:57 PM
ScionDad's Avatar
The Xetronic HID kit requires the use of ballast to fire the lights. I don't think any HID kits will fire and light up on 12 volts. It uses the existing stock headlight housing and stock harness.
The stock light socket plugs into the ballast, the ballast then goes to the HID bulb that plugs directly into the stock housing.
Old Jan 19, 2006 | 04:35 PM
BeetC's Avatar
1UP Crew
No HID kit will fire on just 12V.
insanelyx, I think you're talking about a projector lens...you don't really need it for the tC, but some say that it's better to have.
Old Jan 19, 2006 | 05:04 PM
SO-CAL_TC's Avatar
oops sorry. so whats a balast? and the projector lens is the little glass dome in front?
Old Jan 19, 2006 | 05:08 PM
jjos1's Avatar
No cutting at all ? also do you have pics? is 10000k very blue / purple ?
Old Jan 19, 2006 | 05:10 PM
ScionDad's Avatar
A balast is what converts the 12v to high voltage to fire the lights.
Old Jan 19, 2006 | 05:57 PM
tcholic's Avatar
finally.........anyways, there is no hid kit out in the market without a ballest....
12000k hid is purple
10000k hid is blue/purple
8000k hid is blue
6000k is white/blue
5000k is pure white
3000k is yellow
Old Jan 19, 2006 | 05:58 PM
SO-CAL_TC's Avatar
8000k hid is blue
6000k is white/blue
5000k is pure white
3000k is yellow
if the hids say h9 which of the above is it?
Old Jan 19, 2006 | 06:00 PM
tcholic's Avatar
o yea and most stock vehicles from the factory use 4500k its yellowish/white that the legal color for the road, the reason why they look bluish purple sometimes is the ellipsoid magnifines the light and changes the color much like you would see in a prism.....
Old Jan 19, 2006 | 06:03 PM
tcholic's Avatar
h9 is the bulb type.....what fits in our low beams is a 9006 bulb.......
the different kind of bulbs you will commonly see are....
h1 bulbs
h3 bulbs
h7 bulbs
h9 bulbs
9005 bulbs
9006 bulbs
d2s bulbs
d2r bulbs
and some others i cant think of
Old Jan 19, 2006 | 06:08 PM
tcholic's Avatar
As light color increases, output decreases.
3K, 3K, 4K, 4K,
5K, 5K, 6K, 6K,
8K, 8K, 10K, 10K,
12K, 12K, 3K, 3K,
Old Jan 19, 2006 | 06:09 PM
SO-CAL_TC's Avatar
yeah the light bulb sits in like a dark blue/purple cone shaped piece.
