Horizontal Headlight Bulb Aiming
I've searched google and this forum along with ystc but can never find the screw to horizontally adjust our headlights.
I think I also suck at typing the right stuff in the "search" field cuz, well, search doesn't exactly work as well as everyone makes it seem when they say "just search." It usually pulls up like 100 threads that don't help at all.
Anyway, forget that - horizontal headlight adjust??? I've seen a few threads on it, but they all ended with no answers. One simple, quick answer would be much appreciated. Thanks.
This might help..It's for 05-07, but I;m sure it'll be the same.
http://www.trdsparks.com/install/tCHdlightAdj.pdf
Originally Posted by danboriss
HIDs put in, so i guess put it in, twisty turny. not lined up perfectly. it's not THAT noticeable, i can just distinctly see the two cutoffs overlapping.
SW 08 I live in OB 2 minutes from Oasis.
Don't got any pics atm. You know how the beams cutoffs will sort of "staircase" downwards towards the driver side? I can see like a lighter area of light (almost looks like a shadow, but its merely an overlapping it seems) where they overlap at one section, I guess it is hard to explain. I've seen pics of other people's cutoffs that look similiar. I'll attempt to find a similar shot that may already be floating around.
Ok kinda like raptor's cutoff in the pics on the page in his thread https://www.scionlife.com/forums/vie...toff&&start=60. I know his are retrofitted; but it's similar cutoff. I guess I'll try lowering/raising the one that looks like it might be throwing it off that makes it appear to be a horizontal issue. Maybe I'm just blind and it's just one being vertically off, or a slight rotation of one of them a certain direction.
Well mine doesn't look like that at all. His is different like you said since it is a retro fit so the lenses were probably misaligned when they were put together. You can try to move them up and down to see if it helps but there is no adjustment for side to side one the stock headlights.
Are you talking about the non overlapping area right after the step in the cutoff on the ds projector? This is normal for projectors unless your headlight beams never converge. The halogen projectors in your headlights do this just like the xenon projectors in raptor's retrofit do...
