How costly is it to replace/fix a Driver side quarter panel?
Old Jun 21, 2021 | 05:28 PM
driver07's Avatar
Default How costly is it to replace/fix a Driver side quarter panel?
How much would it cost to fix this Driver side quarter panel damage? Located in NY / NJ
Any help appreciated
Old Jun 21, 2021 | 06:27 PM
drizzoh's Avatar
To do it right? You're looking at a couple grand easily. Will vary based on shop rate and current price of replacement parts and how good of a job they do blending the paint.
Old Jun 21, 2021 | 06:42 PM
driver07's Avatar
The shop i chose wants to replace just the skin instead of the whole quarter panel to save around 12 hours of labor - what do you think of this?
Old Jun 21, 2021 | 07:47 PM
drizzoh's Avatar
As long as the inner framework is structurally sound, that should be fine. Won't know completely until the outer skin is cut away. Probably looking at a minimum of $2500
Old Jun 30, 2021 | 09:48 PM
DannoXYZ's Avatar
Moderator
Moderator
Inner body should be OK. But that's to be measured after removing outer skin. They place car on jig and measure diagonal distances between various reference points to find if anything's bent. Would end up causing wheel-alignment issues and replacement skin won't fit right. Amazing the machines they use to bend body back into shape. Looks like giant robot doing origami!
mandos
78
Jul 6, 2017 11:05 PM
libertyperucho
Scion tC 1G Aero & Exterior
Jun 30, 2009 03:31 PM
stick_1NZ
26
May 29, 2008 01:27 AM
Mikeydizzle
Jan 24, 2008 04:37 PM
O5_TRD_tC
Sep 27, 2005 02:22 AM
