how to take off the door handles?
Old Sep 8, 2010 | 12:27 PM
kayi078's Avatar
Default how to take off the door handles?
Planning to put 3m di-noc vinyl on whole car but first thing need is to take off the door handles? any DIY with pics???? I searched but no result
Old Sep 8, 2010 | 12:36 PM
i_ride_naked's Avatar
by looking at your avatar im assuming that you have a TC. heres a DIY for an xb. it could be the same concept, IDK. hope this helps atall G/L
http://www.clubxb.com/forums/f16/diy...oor-23178.html
Old Sep 8, 2010 | 12:43 PM
juzlookzfazt's Avatar
There should be a plastic grommet on the door jamb area of the door itself, remove that and you should see a 10mm bolt. Remove that bolt and wiggle it off. Hope that helps. Just gave you a quick response but I haven't removed a tC door handle since 07 lol.
Old Sep 8, 2010 | 12:54 PM
kayi078's Avatar
is there any rods connected to the door handles? how easy to remove?
Old Sep 8, 2010 | 03:11 PM
egobuster1's Avatar
just guesssing but ya im sure there will be some rods and cables connected to it
Old Sep 8, 2010 | 05:32 PM
frankiietc's Avatar
Ok man, go to the side of the door..there is a black, rubber piece, or could be just a black piece glued on, take it off..your going to see a star bolt most likely,unscrew it, but remember that it has something so that it wont fall off or screw out,grab the piece that the key goes in the door,it should come out, then grab the handle and push it towards the back of the car and it should be out.Its so simple it can be done in 2 minutes
Old Sep 8, 2010 | 06:50 PM
jaylouie's Avatar
heres a tech article that might help your halfway
https://www.scionlife.com/forums/sho...411852#2150681
Old Sep 12, 2010 | 04:29 AM
If I remember correctly there aren't any rods. The way they build it you can remove the entire handle without having to disconnect any rods or whatever. I was surprised when I first took one off years ago.
sciongirl13
Scion xA Aero & Exterior
Jul 22, 2015 02:28 AM
trikkonceptz
Jun 7, 2015 01:46 AM
mischadoll
Mar 9, 2015 05:48 AM
toyotaisme
Jan 10, 2015 10:24 PM
wizzlexB
Dec 27, 2014 04:06 AM
