Lip kit on 08 tC yes or no
I have a 2008 tC and i am now considering on adding a lip kit, if i do go for it i definetely have decided to go with the OEM one as my choice, but i would like to first off hand get some opinions since i have not seen any with them on, i also already have the rear trunk lip spoiler on, another thing to take into consideration..heres some pics of my 08:
u might scrape a little bit here and there on big inclines... but yea... 08s look like 07s... as do 07s 06s and 05s... look for any tC with a OEM lip kit and thats how yours will look.
he also has a different kit. The OEM lip isn't THAt much lower than w/o. You'll be ok w/ a TRD drop, you just won't want to crawl up to close to a curbed parking space. the 2in drops will scrap on some inclines/declines, but you should be able to use your judgement when you come up to them. Alot of them can be taken at an angle and avoid scraping altogether
actually here is what exactly stated regarding the TRD springd:
All TRD coil springs are manufactured from high quality chrome-silicon wire and powder coated, and all are designed to lower the vehicle, usually from 1" to 1.125". Lowers the tC approx 1in., lowering the center mass for reduced body roll & quicker response. Provides 10% stiffer spring rate for added stability.
Originally Posted by PlayinWithFire
I had the oem lip kit with TRD drop back in the day...
i miss that car lol, but i like how it looks now
.the last pic you posted, i did a p/s of it with the front lip molded awile back
just so you know, the OEM lipkit is NOT available just by itself PRE-PAINTED. You need to purchase all 4 peices that will be color matched at once. OR you can get a lip that is PRIMERED and have it painted.
No worrys on rubbing, I have the TRD 18" 5 spokes (NOT the tC 18" EMX upgrade) , trd springs, and shocks+struts, plus the OEM body package, and there is no problems. I mean, if your going to hit something, its not because of the drop.
