NEED HELP retrofit question harness!
so i bought the retrofit headlights off extc and now its all installed but my headlights wont turn on , is it because i dont have a relay harness to draw power from my battery or d2s harness?!?!?! i even got a test ballast from au2tek to test it out but it still wont turn on i dont get what the problem is its not the fuse checked that nothing broken and i didnt miss any plugs !! can anyone help me? i thought hids dont really need a relay to even use it!
check the fuses 1st. what do you have to get power from, is it just wired into the low beam sockets? If so you need to get a relay and this is what mine looks like.
Yellow and Black wires to ballast, red and black to battery and blue to low beam.
buy it by emailing someone at the bottom to make you one...
http://www.hidplanet.com/forums/viewtopic.php?t=20144
if you can, bench test your ballast to make sure you didnt reverse polarity your ballast. What ballast do you have anyways?
Originally Posted by haiduy
hes a guy on sl haha thanx yanki i know you did the retro fit so ima get 9006 relay harness and try it
Yep. I retroed that. What ballast do you have? Try taking the bulbs out and test them with the ballast. Make sure you plug the stock 9006 socket to the ballast correctly , - to - and + to +.
i got the ballast he used the mcculloch and i have another one to test and they are GHC by au2tek both dont work
