Need some help bad please with fogs!
Ok guys i have been searching for hours now on tyring to figure out the TC wiring.
I'm gonna be putting in some projection style fogs with H3 bulbs. and would like to wire them to factory wiring harness. but im stuck here.
1. what do i need to tap into stock harness?
2. i have a whole harness off another set of aftermarket fogs can i use this relay and fuse and tap into harness?
does anyone have a wiring diagram for the fog light harness already put in the car? sorry for all the questions just at a loss here!
pink wire behind driver side fender is were the (+) wire for the fogs comes from... doubt you have the connector.. but you can just tap it from there...
you will need to find another ground for the fogs though...
and inside... there's a plug harness behind the panel under the switch panel...
there you'll find the connections to connect the switch/harness that you need to get power running down that pink wire.
alot of crap to deal with if you dunno what you're doing... you might be better off running your own harness and wiring.
so if i tap the (+) from the fogs into the pink wire ground fogs to chasis somewheres i can use the fuse box to fuse it and relay? i take it th relay is already there then? and if so what amperage fuse is there now? thanks for you help so far by the way!
carid
Jan 8, 2015 11:33 AM
TheTripleC
Jan 4, 2015 06:46 PM
