OEM Lip Spoiler Install
just install the spoiler using this technique, very easy and no holes in your car. https://www.scionlife.com/forums/vie...071996#1071996
i used double sided tape to install mine like the above link. the install is easy and even if you don't have tools, just buy some and you'll still come out on top. the only tool i needed was a dremel.
I saw that tutorial before. There is a reason why there are bolts, security. Bolts are the most secure way to mount a spoiler, bottom line. it will withstand lots of pressure, water, and is the proper way to do it. Even with 3M tape I can't guarantee the same.
it's probably one of the easiest things to install on your car if you'd like to install it that way be my guest. you just drill a couple holes and you're pretty much done, no special tools required so you should have everything you need already.
TheTripleC
Jan 4, 2015 06:46 PM
umnitza
Dec 1, 2014 06:26 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
