Is it possible??
To open up my headlights with a heat gun instead of an oven?
My step dads kind of a douche and wont let me use ours cuse he said if i do it the plastic releases gases that can exficiate (no idea how to spell that) me
So can i use a heat gun?
Put the lamp in a foil lined box and blow air into the box with the heat gun like an oven - just watch the air temp - carboard will ignite at some point over 454F. If the box is made from foil covered sheet insulation it will work great.
Check this DIY - it's for halos, but same applies for baking open the lights.
https://www.scionlife.com/forums/viewtopic.php?t=176590
From the beginning of the post:
This install requires that you bake your headlights, so if you're not comfortable with subjecting your headlights to 225 degrees for 15 minutes then I dont suggest this mod.
i used a hair dryer all you have to do is have a friend pry apart while you apply heat once it starts to open then just keep working your way down starting from the blinker to the parking light it took me about 10 mins
