Question on ABS front lip installation
Just did a test fit of the ABS Dynamics front lip, and the center portion hits the lower grill. This pushes it forward about 3/8" and causes some bad gaps.
For those that installed one, did you cut the middle out of the lip? Or pop out the grill and force the lip under it?
I trim'd mine, but I didnt want to. When I go turbo, im taking out bottom grill piece for the FMIC, and you'll be able to see where the lip stops..
Only thing Im worried about is the sides of the lip where there is a little gap.
Now if I decide to do a metal mesh grill I'm likely screwed, like you said. Ahh well, looks good for now.
Originally Posted by sp0t
yeah thats a flaw for the abs versions... ,u cf lip fitted flawlessly.
Still trying to decide how to remove that little hole, sucks for you though...Carbon Fiber doesnt really flex, and if it does... forget about it..
oh yeah, everyone has that issue.
When i said it fitted flawlessly, i was referring to the center flange that seems to be long enough to go past the lower grill.
for that little "hole", it doesn't bother me one bit.. its not even considered a gap to me, i could barely fit a piece of paper into it.
Yea I need to fix mine.. It tends to collect small rocks.
Oh, and for better fitment overall, use a dremel sanding drum to chamfer the edges of the lip on any near-horizontal areas of the bumper. Like around the ducts and the center grill area. It allows the lip to snug up nearly flat with the bumper,
That dosen't bother me either. CF is not flexible, so that's the best it's going to get. I think the asthetic value outweighs the slight gap on the sides.
lol i kno how u feel but its all how u mount it and if u want it to sit lower or not.. if its sits flush the sides look waaay to low.. but if u make the sides sit higher u get the slight gap... its anoying but still looks great
seriously.. wow i was suprised that my cf one had pre-drilled holes and my abs ones didn't have the holes.. i bet that it was the new batch of lips that have the holes predrilled, my sponsor picked it up directly from abs dynamics, rhythmnsmoke at least u did a great job on the holes doesn't look like any cracks.
