rear emblem help?
im not quite sure...i just got a shaved garnish instead....if it's anything like the xB2s then it has two little wholes in order to keep it centered..and glue....it should be too hard to remove...you'll be able to see it once you remove it.
use an old credit card and a heat gun to loosen it up around the edges. Just keep pushing the credit card under it and it will pop out. There are 2 tabs on the back of the emblem so just be careful you dont break those off and you'll be fine.
killahXB2
Mar 29, 2016 04:22 AM
