Rear Lip Install
Old Feb 19, 2011 | 07:38 PM
dookie1427's Avatar
Default Rear Lip Install
Quick question.... I've got the oem rear lip but the tabs that require to make cut outs to the bumper arent there. Is there a way to make it stick to the bumper? I've tired double sided tape and that doesnt work. Any suggestions?
Old Feb 19, 2011 | 07:55 PM
yellowxhoodie's Avatar
3M double sided tape. The red stuff. Its alot stronger than reg. double sided tape. Only problem is if you ever decide to take it off, it may take the paint with it.
Old Feb 19, 2011 | 08:00 PM
dookie1427's Avatar
Thats the stuff I tried but no luck especially on the piece that goes above the exhaust tip
Old Feb 19, 2011 | 08:19 PM
Macavely's Avatar
if the lip is going to stay one for good.. then clean the area with the tape is going on.. make sure all the dirt, wax, is off... put some can or what ever can fit under the lip to hold it in place.. and let the glue on the tape get a good seal for a few hours..
Old Feb 20, 2011 | 12:48 AM
midnight_blue's Avatar
try using a heat gun also make the tape very sticky
Old Feb 21, 2011 | 07:09 AM
speedismyneed's Avatar
There isn't enough surface area to use tape on that aftermarket lip.try to use a drill if you have one..
torranosaurus
Jan 28, 2015 04:53 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
wesley_t
Dec 18, 2014 06:59 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
