removing license plate lights
Old May 21, 2009 | 02:07 AM
SoulXquisite's Avatar
Default removing license plate lights
i got some high powered LED from superbrightleds.com
but im just having trouble removing the socket of the blub from the car.
am i suppose to turn counterclockwise to release the blub housing?
-i looked at the diagram, thats what it looks like, but not really budging, not trying to force the darn thing might break it since its just plastic, someone help if ya can.
Old May 21, 2009 | 02:12 AM
ExpresScion's Avatar
Get some needle nose pliers and use that to twist. If it's the first time your removing them, it's gonna be hard.
omgu8myrice's Avatar
twist it hard, i think it was counter clockwise, itll pop out, use a wrench, it helps. then you pop the bulb out and replace, and your done
Old May 21, 2009 | 02:13 AM
daffy12's Avatar
yeah pliers will help out a lot. just dont squeeze too hard or they'll crack...
what kinda LED's did you get??
Old May 21, 2009 | 02:56 AM
luuserface's Avatar
^^ his first post said he got it from superbrightleds.com.
I wanna do this too! Such a subtle and inexpensive mod.
Old May 21, 2009 | 04:23 AM
daffy12's Avatar
Yeah but what kind. The 5 LED. The 6 LED. I myself got the one high powered LED. Things are sweet. Light up the whole ground behind my car
Old May 21, 2009 | 04:28 AM
liltofuboix's Avatar
just use pliers and pluck them
Old May 21, 2009 | 04:38 AM
tc-guy's Avatar
use a small towel wrapped around the socket with the pliers or else there will be hella scratches left on the socket.
Old May 21, 2009 | 04:56 AM
Iceman04503's Avatar
i used a slip joint plier
Old May 21, 2009 | 05:25 AM
- got the same ones like u did, but to of no avail did i get the damn thing to get loose, plus i was pressed for time since i had to go watch a movie
Old May 21, 2009 | 04:54 PM
mason239's Avatar
watch out for the tabs on the hatch when your getting to it, i had a couple break and they seem to sag sometimes
Old May 21, 2009 | 05:00 PM
SW_08's Avatar
Old May 21, 2009 | 05:03 PM
Ace83's Avatar
Ronin Scion
^^ x2.. they are pain to remove for the 1st time
Old May 21, 2009 | 07:21 PM
EDDIEA123's Avatar
When i first removed mine I had about 5-7 differnt guys try to get that thing out and no luck....the pliers were the heros!!! Thank god for tools!
Old May 22, 2009 | 06:50 AM
luuserface's Avatar
Why would you twist the bulb? I thought the bulb were wedges?
I know, its probably a stupid question, but I'm about to do it too. hah.
Old May 22, 2009 | 08:25 AM
First time I actually broke both of mines so I had to order 2 new ones. Thought I would have learned after one but I guess not. They were pretty cheap to replace.
Old May 22, 2009 | 01:50 PM
daffy12's Avatar
You don't twist the bulb itself. You twist the socket that the bulb sits in. Its a plastic piece.
Old May 22, 2009 | 05:17 PM
-sweet the split joint pliers did the job, better than the needle nose. thanks u guys.
mission accomplished!
Old May 22, 2009 | 05:19 PM
tcday's Avatar
these lights r a pita to get out took me almost a whole yr
Old May 22, 2009 | 05:40 PM
- angled pliers helped out too....-
