Shaved Garnish Problem
Old Dec 19, 2010 | 10:10 PM
sebbyxtc's Avatar
Default Shaved Garnish Problem
I did a garnish on my own, bondo'd it smoothed it out, primed it, and painted and cleared it myself. I installed it about 4-5 days ago, the last 2-3 days its been raining. Anyways idk if its because of the rain but i was looking up close at it and its starting to turn like yellowish around where the bondo was put at. Its in excellent condition other than the yellow rising. Painters or anyone who knows what it is, what went wrong or can give me advise let me know!
Old Dec 19, 2010 | 10:12 PM
sebbyxtc's Avatar
^^ you cant really see cuz it was a cell phone pic but if you look closely you can, i will try to upload some pics asap.
Old Dec 19, 2010 | 10:44 PM
Basebllstar's Avatar
I did mine myself and haven't had any problems. If the only problem you have is in the bondo area, then chances are it has to do with the bondo. maybe it hadn't dried all the way? Idk. i did mine over the course of a week or two so it had plenty of time to dry.
Old Dec 19, 2010 | 10:56 PM
sebbyxtc's Avatar
That might be it but im not sure:/
i let the clear dry like 2 days, and the bondo like 1 day or so before i primed it
Old Dec 20, 2010 | 03:11 AM
Is the bondo sunken or popping out? How many coats of primer did you use?
Old Dec 20, 2010 | 06:03 AM
sebbyxtc's Avatar
Nope, it was smooth as a feather. I would say 4
Old Dec 20, 2010 | 06:25 AM
Frizz's Avatar
Team ScionTific
you didn't let the bondo driy enough and sounds like you used a cheap paint.
PS you shouldn't use bondo. It's ____ty and will crack in time.
Old Dec 20, 2010 | 06:54 AM
sebbyxtc's Avatar
^Then what do you suggest using? As far as filler goes.
And no i didnt i used OEM Super white paint from automotivetouchup
Old Dec 20, 2010 | 07:27 AM
Frizz's Avatar
Team ScionTific
polyester filler. MAKE SURE you used the correct amount of hardener. Use to little and it wont dry, use to much and it will crack.
Old Dec 20, 2010 | 07:39 AM
sebbyxtc's Avatar
So what do you suggest i do to the garnish i have on at this point to fix it? The oem one i had on there ima do the same to. But i wanna fix the one i have on there.
Old Dec 20, 2010 | 08:07 AM
Frizz's Avatar
Team ScionTific
take a chisel and take out as much bondo as you can and then start over. Make sure you let the coats dry for a good amount of time in good hot weather befor reinstalling.
Old Dec 22, 2010 | 06:57 PM
diego1103's Avatar
I thought automotive paint was water proof , how would it be able to soak through to the bondo?
Old Dec 24, 2010 | 01:54 AM
Aurora's Avatar
Should answer your phone Sebby, I called you twice my man.
Hit me up after yule.
StatuSCheckA
Scion tC 2G ICE & Interior
Dec 4, 2014 03:15 PM
1sikxb
37
Oct 13, 2004 02:37 PM
Opr8r
38
Mar 1, 2004 11:24 PM
boxzila
34
Jan 12, 2004 03:27 AM
dockwriter
Oct 29, 2003 10:55 PM
