stock compare to silverstar
Old Dec 21, 2005 | 10:52 PM
bdballer69's Avatar
Default stock compare to silverstar
At first i didn't know the difference after i look at the pic i took with my phone i can see the difference.
Before:
After:
On the side note, the feet (connecter) of the silverstar bulb is different than the stock one.
Old Dec 22, 2005 | 12:11 AM
TexazBoy731's Avatar
I just put on a set of Silverstars yesterday and man do they look good! WAY better than the Streetglows I had on there before!! Those looked very ricey!
Old Dec 22, 2005 | 12:19 AM
bdballer69's Avatar
nice
Old Dec 22, 2005 | 05:24 AM
WeDriveScions's Avatar
Silverstars are a great DOT legal option, probably the best DOT friendly option out there...
Old Dec 22, 2005 | 05:46 AM
hawaiiguy's Avatar
which silverstar?
Osram's or its subsidiary, Sylvania?
I had the Osram Silverstars, and it was way *brighter*...if you compare that to the sylvania silverstars, the sylvania will be *whiter* due to that tinge of blue.
there is a *difference* between the two silverstars...
Old Dec 22, 2005 | 03:19 PM
Generally, Silverstars are Sylvania... as OSRAM are really not widely available at US stores....
I love the OSRAM bulbs, as they are brighter, but always have to order them online, where-as I can pick up sylvania's at almost any local store.
Old Jan 29, 2006 | 01:21 AM
glen619's Avatar
left is silverstar.
Old Jan 29, 2006 | 01:35 AM
zer0's Avatar
yea, i need to get my high beams now, nasty yellow over clear white is buggin me... Silverstars FTW!
Old Jan 29, 2006 | 01:52 AM
SciontCya's Avatar
Big Sky Scion
SS's are great bulbs.
If you're into blue/violet bulbs, the GP Thunders are nice and don't fry wires.
If you want LIGHT, try the SS's.
Scott
Old Jan 29, 2006 | 02:21 AM
Dakahn's Avatar
Yeah, time for change as well. Should have done this a long time ago!!!
Old Jan 29, 2006 | 06:27 AM
_-Dark-_-Scion-_'s Avatar
the 9006 bulbs would be the ones for the TC? sry for bothering your thread, but Does the HID's void any warrenty. I wanted to ask you guys instead of calling the dealer.
Old Jan 29, 2006 | 07:47 AM
Hyghgynx's Avatar
Default Re: stock compare to silverstar
Huh? When I changed my Hi's & Low's to SilverStars, I had no problems. Simple Plug-N-Play. Took all of about 15 minutes for all 4 lights. One of the easiest mods I have done to my tC. Did anybody else have a different connector on their install? Maybe I have different SilverStar bulbs than you? 9006 = Low Beams. 9005 = High Beams. I think that's right. The good ol' Capt. & Coke is kickin' in!
Old Jan 29, 2006 | 10:57 AM
SciontCya's Avatar
Big Sky Scion
^^^ Same here. Not sure what he's talkin' about...
Same for other brands too.
Scott
Old Jan 29, 2006 | 11:10 AM
toyota_scion_tc's Avatar
I had silverstars and threw them away. They seem dimmer than the factory bulbs. I bought gp thunder 8500k high wattage bulbs and these bulbs are great. I paid 16.99 per set and these are the closest bulbs I have found to HID. They a 100% legal and dot approved. These bulbs will not harm your factory harness either. They have a ion coating that helps prolong the life of the bulb even if you touch the glass before installing it. Definately work the money! www.globalpremier.com has these.
Old Jan 29, 2006 | 11:14 AM
SciontCya's Avatar
Big Sky Scion
^^^ I bought those, but in the end, I opted for normal wattage as I was not going to buy new harnesses...sorry, I know you told me yours were fine, but I chickened out!
They are nice bulbs though, but standards are not as bright as stock, or IMO, the Silverstars.
So, I have three sets of bulbs which means I keep spares in my trunk
Scott
Old Jan 29, 2006 | 11:48 AM
imsonofagun's Avatar
There are two versions of the 9006 and 9005 bulbs. One says ST at the end and the other says XS.
From the Sylvania sight:
9006XS SilverStar Headlight
High Performance Halogen Headlight - Single filament for low beam -
XS = Straight Base, same performance as the 9006ST - part number: 9006XS ST
9006ST SilverStar Headlight
High Performance Halogen Headlight - Single filament for low beam - part number: 9006ST (angled base)
Old Jan 29, 2006 | 12:39 PM
Scott
These bulbs are designed not to mess up your harness. I had bulbs 5 years ago that melted my headlight plugs. They started showing sings after a month. I have been using these bulbs for 6months no signs of any issues with the gp thunder 8500k high wattage bulbs. I checked my plugs and harness and they are fine. You have nothing to worry about.
Old Jan 29, 2006 | 02:28 PM
speddlysmitt's Avatar
One of my Silverstar's burnt out after 5 months. Went back to stock.
Old Jan 29, 2006 | 04:18 PM
SSMtC05's Avatar
My silverstars lasted 16 months before one failed me last night, im off to get another set today.
Jay
Old Jan 29, 2006 | 06:14 PM
SciontCya's Avatar
Big Sky Scion
The problem I have with "don't worry, it won't fry your harness" is that I've emailed every one of these sellers that say this and ask "will you replace my harness if it does fry it" and NOBODY ever replies!
If someone says it, it means squat (not talking about you) unless they back it up.
I might try it down the road - I just don't want to be ordering and installing a new harness on my new car!
Scott
hampton1100
May 28, 2015 07:32 AM
SloTC1
Apr 2, 2015 07:11 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
rast3r
23
Jul 6, 2004 04:42 AM
tbblizzard
Dec 12, 2003 01:48 AM
