VRD INSTALLATION GUIDE
First stand in front of your tC. Then kick out your stock grill with large boot. Then gently put your new VRD grille in the place of the stock ones. They clip in like stock. That simple!
Originally Posted by Swimmer___X
Soooo you have to cut your bumper to fit them in??
Anyone know if the relay is necessary? i had the oem fogs before so i already have a switch just wondering if its fine or if i need to put the vrd switch in? Thanks.
--Keith
Keith, since you had the OEM fogs, the only thing you will need to do it plug in the supplied VRD wire that connects to the fogs. It connects under the driver's side headlight, and then re ground the new wire. If you kept the switch and the relay, they will all work with the VRD set up.
Can VRD Fog Lights Fit on a tC RS 3.0 at all? Will it require cutting like on the OEM lipkit?
A: No, VRD Fog light kit can not fit RS3 Bumper Lip. (basic the vent hole still the same, but RS3 body kit reverse the angle).
are all h3 foglight hid kit like the one shown in the picture?
do they all have the rubber thing?
A: Not really, Some seller take those part off and selling cheaper.
Originally Posted by asnstyle3
can you repost the images/instructions for the installation. The picture links seem to be broken now. Thanks
