02 sensor
Old Oct 26, 2005 | 03:16 PM
sallad's Avatar
Default 02 sensor
Ok so I have the Megan racingheader and the TRD supercharger. My check engine light is on and has been every since I installed the header. When I tried to remove my old 02 it broke, so then I bought an 02 from a toyta camry and installed taht then got the codes erased... 2 minutes later it was back on. So I tired the anti fowler with the 02 sensor then same scenerio.. now I have purchased teh ZPI smart 02 and I will be trying that out soon. However is that doesn't work then what? What type of damage or side effects will there be from havinga faulty 02 reading?
Old Oct 26, 2005 | 03:30 PM
jmiller20874's Avatar
Just to clear things up, you're talking about the sensor on the s-pipe right? Not the header? 'Cause the sensor on the header is not an O2 sensor, it's your A/F sensor and yes it will screw up your car if it's not working.
The O2 sensor on the s-pipe is just to let the ECU know that the pre-cat on the header is working. People have driven many miles with the CEL from that.
Also, go down to your local AutoZone or whatever, and get that code read. You might be fighting the wrong problem.
Read my article to deteremine if either sensor is bad:
https://www.scionlife.com/forums/viewtopic.php?t=89781
Old Oct 27, 2005 | 05:40 AM
sallad's Avatar
Default THANKS
Yeah man thanks a lot I was fighting the wrong problem. I got ahold of ZPI and they got me back on the right track. You helped a lot thanks again.
Old Oct 27, 2005 | 01:28 PM
No problem, anytime.
Old Oct 27, 2005 | 01:45 PM
Beantowntc's Avatar
did the dealer say anything about your header during the s/c install?
Old Oct 27, 2005 | 01:56 PM
Scion_South's Avatar
Nope, everybody here at the dealership thought that his header look great.
Thanks for giving us the chance to install your supercharger Dallas. Oh and a big thanks for giving me a chance to drive it.
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
prescottn
Sep 22, 2015 01:30 PM
gqdabien
Sep 17, 2015 09:23 PM
Topfueltom69
Sep 6, 2015 05:25 PM
