2005 water pump issues?
Hi there,
I just bought a 2005 Scion tC with 147k on the clock. It doesn’t appear to have ever had the water pump replaced. Is this something I should be worried about?
Thanks!
Thanks!
Last edited by MR_LUV; Nov 28, 2017 at 11:07 AM. Reason: moved to Correct Forum by Moderator
Haha - no worries. I have read on some forums about water pump failure on these engines. Some were in tC’s and others were in Camrys. Just thought I’d check!
Actually, some Toyotas do have water pump issues. It is typically bearing failure that leads to leaks. I recently had to change the water pump on my wife's 2008 Rav4 as the bearing were beginning to grind. This was a common issue on the 2GRFE V6 engine.
My tC on the other hand has been going strong. In any case, when it comes to water pumps, if it ain't broke, don't fix it.
If you do replace it, go with the Aisin brand (OEM) and get a OEM gasket. I've done the one in my Tacoma 2.7 three times and dont even remove the alternator. I'm down to 2.5 hours - turn key ready.
If (and even if there is a little) weeping fluid at the hole on the under side of the pump, that could be "normal" and if the bearing felt smooth, then wait and watch for significant dripping or loss in the overflow.
Some of them last 70k, others last 150k but I've always thought the Toyota pumps were hit or miss. I've had a Solara (given to family now) thats past 160k on the original, but my neighbor's Camry had 3 or 4 done by 296k,
It looks like a really fun spot on this car :/
I know I sound like a commercial for Toyota but when you screw around with aftermarket parts you realize why Toyota is more money.. it's better stuff!
