2007 tC Cylinder 3 Misfire
I’m getting a misfire in Cylinder 3, have exchanged spark plugs, ignition coils, fuel injectors and ignition coil connectors (they were falling apart). And still getting the misfire. Anything else I can try? OBD code is P0303 *Moved to Correct Forum by Administrator Sticky Where to Post Your Question Sticky How To Advanced Search SL (Scion Life) How to Turn Off The CEL..How To Diagnose Your Check Engine Light For Free ______________________________ |
Originally Posted by wkndwrz
(Post 4291434)
I’m getting a misfire in Cylinder 3, have exchanged spark plugs, ignition coils, fuel injectors and ignition coil connectors (they were falling apart). And still getting the misfire. Anything else I can try? OBD code is P0303 *Moved to Correct Forum by Administrator Sticky Where to Post Your Question Sticky How To Advanced Search SL (Scion Life) How to Turn Off The CEL..How To Diagnose Your Check Engine Light For Free ______________________________ Lastly it may possibly be the fuel pump. There may be not enough fuel getting to the injectors. But I feel this would affect more than just one injector. As its delivering fuel to the fuel pipe which is feeding all 4 injectors. |
I already fixed it yesterday, but you’re right that was it so they weren’t spaced correctly and causing a misfire. So it sounds like the original misfire was the fuel injector after all and then continued because of the insulators. Thanks for your help |
(Post 4291479)
