air fuel gauge
air fuel gauge
i got all my new gauges today, and im trying to hook up the a/f, i tried tapping into both the white and blue wires coming off the o2 sensor from the header, but im not getting any signal. has any one elsed hooked up an a/f to there tc? what way did you do it? it also might be the gauge, i noticed it was opened when i got it, it might have been returned because it didnt work.
thanks
thanks
posting to see if there is an outcome, as i might get some gauges come 06.
edit: dang I went and got one,....
https://www.scionlife.com/forums/vie...251&highlight=
Originally Posted by Limey
Anyone have pictures or a diagram of the wire you should tap to get the o2 readings ?
It's basically a sensitive LED digital voltmeter, all I need to know is which wire is the O2 wire inside the car.
Our OEM sensor is a proprietary wideband, and it wont wire up correctly (like tap'ing the purple wire on most OEM narrowbands). I don't know of anyone who has tap'd into our sensor correctly.
Most, like me, just put our own sensor in.
Not sure how it couldn't wire up correctly, surely it's just passing a voltage ?
Not all sensors have to pass a voltage, it could be an inductance or resistance value across the sensor, which would make alot of sense why people havent been able to tap off the tC sensor like most narrowbands
So where would the tap go if there was one? Where's the easiest place to test to see what this thing is pumping out, all I need to know is where the wire is and I'll hit it up with a meter.
OK, so how much is a basic wideband sensor, and how easy are they to install?
If you were going to try to tap the narrowband sensor (which our car doesnt have) there would be three wires comming from the sensor: two for power (generally red or black and a white) and one for signal (I've seen green and purple). The signal wire is what you would tap off. You can do this either from outside the firewall and route it in the cabin or try and find it on the wiring harness before it hits the ecu. I'm not sure the color of our wires.
However, our wideband O2 doesnt read right when hooked up to a controller, and it's slow response so, worthless for what we want.
So you have two options and both require welding a bung on your s-pipe to mount a new sensor. You can buy a new narrowband sensor (try the autometer part #2244, ~$100) and run a narrowband gauge which pretty much is only worth a light's show as it says your running stoich, or not.
Or you can get a wideband O2 sensor which requires a controller, a good package is the LC-1 from innovative ($200 + Gauge) which is reprogramable to work with narrowband gauges like the autometer's, and comes with a Bosch heated oxygen wideband sensor. You can also use one of the two analog outputs to log A/F in their free software so you can tweak on the street. Widebands tell the exact ratio in a voltage between 0-5V generally. The voltage matches up to a conversion table and you get your true A/F Lambda value.
Dyno's use wideband controllers and wideband sensors. If you already have one installed, theyll use it, otherwise they have a couple methods depending on how your car is set up to get a probe in there, like if you hfave no cat's installed they can use a tailpipe sensor probe.
Does anyone know the part number of the O2 sensor?
Does it appear in this list: http://www.discountconverter.com/O2Sensors/
In order to do it, you need a wideband O2 setup... with a separate sensor bung welded into the SPipe...
I'm going with either innovate or PLX... They will be your best best to accomplish what you need...
Do not look at narrowband or try to tap into the stock sensor... no one's been able to do it.
Count on about 350 for a good Wideband setup.
I'm leaning toward the 250 with the guage.... I can put it with my nitrous pressure and fuel pressure...
I also can get the M300 new locally for $300 as well... Sorry.
