All motor or TURBO???
I have not made up my mind if i should go Turbo or all motor.
How much HP do you think i can get out of the motor w/o any FI????
Would it be worth going all motor??
Any opinions???
Thanks
Any opinions???
Thanks
Ok. Per Greddy the kit they will be releasing some time this year hopefully......is going to run about 3,500 to 4,000.
It will be set at a safe setting and add about 70 to 80 hp but thats already pre tuned. Obviously it can be tuned to put out more. So lets say with just the pre-settings i can get about 200-230 whp.
For that kind of money what do you think i can get out of all motor? No NOS!!!
If i could get about 250 to the wheels all motor for about that price i would be satisfied.
If you really want all-motor power, here's some ideas:
*Go with a full stand-alone ECU (motec, haltech, etc)
*Individual throttle bodies (custom throttle system needed)
*race ported head, with NA cams
*new lighter pistons, higher compression (like 12:1)
*mandrel bent exhaust
*port-matched intake and exhaust manifold for your ported head
*clutch and flywheel
That should help. But for less than half of what that would cost, you could be boosted by one of the companies (including myself) on this board and make more power, and a lot more torque.
Your looking at an expensive setup considering theres almost noting out for the TC.
The basics to N/A
1. Intake ~$220
2. Exhaust ~$600
3. Header ~$550
4. Custom Cams ~$800
5. Ported Head ~ $550
6. E-Manage ~ $900
Then from there on you get into more serious components, like Joe stated above.
What I mentioned was just a start. It will yield about 215whp for about $3600. The N/A route is a lot more expensive than the turbo route. For about $3000 you can buy a turbo kit that makes about 240whp. Whichever path you take don't forget to upgrade the tranny, suspension, and tires for optimal use.
The basics to N/A
1. Intake ~$220
2. Exhaust ~$600
3. Header ~$550
6. E-Manage ~ $900
Originally Posted by matty-tC
header for $550?
cams are cheaper.
exhaust can be done cheaper. emanage is max $400.
cams are cheaper.
You can buy the lowest priced items, but I prefer to stick with the best (whatever gives best performance). I am not saying something has to be expensive to perform, but I was just averaging what different people might spend.
emanage ultimate for a naturally aspirated setup is a waste of money. i'm not sure why you think it's better in that case.
B_Real45
Feb 23, 2015 07:33 PM
