Any Chance???
I searched already but I found no answers. Is there any chance that I may be running lean due to my I/H/E setup? oh and I have no CEL. The reason I am asking is because everynow and then my car will start idling hard at around 500 and shaking my car a bit. I do have the ingalls stiffy which might be at fault but i doubt it.
hard idling will not define if you are running lean or rich because when you are idling...there is very little fuel being injected into the engine. You could have an exhaust leak/leak near the header...your MAF sensor could be getting some different reading...it could be cold outside. There's a bunch of reasons why it would idle hard...but it doubt that it's because it's running lean. How does it run while driving and under full throttle?
if it runs fine, then ur probably ok...u will run a little leaner than stock due to your setup...but nothing even remotely near to dangerous...unless u are also supercharged and untuned
your not lean or rich that would effect normal driving more than idle. 500 is a real low idle though, and im not sure if the Tc is an automatic idle control or if it is a manual adjustment
yeah.. mine idles funny sometimes but that's only when im at a complete stop and the idle drops to about 600 for like 1-2 seconds then will go back to normal.. but that's like once every three days.. is that normal?
check your spark plugs..... the color should tell you if you are running lean....hard idle is probable due to the stiffy... I noticed it on mine when I installed my MMW damper.... I noticed it more when I installed the ZPI engine stabilizer bar.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
