Any final thoughts?
ok next week...
Tsudo 4-2-1 header
Tsudo midpipe (with magnaflow HF cat, and Aero 25 Resonator)
Tanabe concept G axle back (which i already have)
any tips or advice install, or should i do something different
Tsudo 4-2-1 header
Sounds like a pretty good set-up, a few things you should remember...
1st: Make sure to have a lot of patience and time for the install esspecially with the header.
2nd: Make sure to take out the fans before trying to make the header fit!
3rd: Have fun with the set-up and be safe.
Yea!
They are the radiator fans (facing the header) and they only have a few bolts, and some wiring. It takes about 5-10 mins to takes those off. Make sure to read some DIY so you don't get stuck in the middle of the project.
Oh ok, my bad I misunderstood what you meant.
What I have heard and know from installing my header is that you will not be able to angle the header in with out the fans being removed. This is because of the way the header angles at the bottom where it connects to the s-pipe.
Anywho Good luck bro.
The reason you didn't have to remove the fans is because the Alphawerks Header set-up is a completely different design, it is a 4-1 design.
The MMW/Weapon-R 4-2-1 and Tsudo 4-2-1 header has a different bend, design, and length.
If you look up both Headers you will see the differences.
BAMF4Life,
How much did you get the Aero Resonator for?
BAMF4Life,
ok in that case i will def. post a vid.
that way no one run into the same mistake.... (if it sounds like *****.)
i hope its sounds good though... and i hope i get some power
crystaljukebox_com
39
May 14, 2004 04:55 AM
