Any Magnaflow Catback Tech or Installation Guide?
Old Jun 27, 2006 | 02:25 AM
20tCDude05's Avatar
Default Any Magnaflow Catback Tech or Installation Guide?
I will be installing my Magnaflow Catback in about 2 weeks and I've never done one before and not sure if I can do it myself, I don't have a lift nor have access to one, so the car will be on 4 jackstands. So, just wondering how long it would take, the difficulties, any problems or hard parts I should look out, etc. Hope I could get some assistance...
Old Jun 27, 2006 | 02:36 AM
20tCDude05's Avatar
And I did look if there was one and didn't find one. Just so you know, I did search...
Old Jun 27, 2006 | 03:06 AM
mattvs's Avatar
It should come with all the parts. However, when I ordered my Magnaflow cat-back (ordered from Creative Compacts back in...December), it required a cut. You may want to check that out before you get your car lifted up and your stock exhaust uninstalled.
If not, it's a matter of unbolt, unbolt, unhook, remove...hook hook bolt bolt start up check for leaks and go. About as simple as it gets. If you can change a tire, you can bolt on an exhaust.
Old Jun 27, 2006 | 03:31 AM
20tCDude05's Avatar
Aww, a cut, I don't like cutting, wiring, welding, etc.
Old Jun 27, 2006 | 03:41 AM
mattvs's Avatar
Well my exhaust is an older version, they may have changed it and you probably didn't order it from the same place I did. :p
Besides, if it required a cut, it would've said so in the description
Old Jun 27, 2006 | 04:10 AM
noTCed's Avatar
Default .
did mine last month was simple cut old exhaust off bolt new one on
Old Jun 27, 2006 | 04:43 AM
20tCDude05's Avatar
I'm praying that there's no modifications necessary to install mine...
Old Jun 27, 2006 | 01:44 PM
rOmEro's Avatar
Here is all the info you need. Sound clip video, dyno, and installation guide for the Magna Flow exhaust.
http://www.magnaflow.com/02product/s...=Sport&id=1002
http://media.putfile.com/MAGNAFLOW-EXHAUST-tC
Looks like its an easy install just get a saw to cut the stock exhaust. I personally do not have this exhaust. I got the TRD Muffler a long time before this came out. Although from what I see the Magna Flow goes from the cat 2.5" all the way to the back and then 2.25" stock diameter to the axle back. The stock exhaust with TRD Muffler goes 2.25" all the way to the back and then 2.5" to the axle back. Seems like you would get the same air flow. But I am by no means an expert. Hope you like it. Has a nice growl to it!
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
TheTripleC
Jan 4, 2015 06:46 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
